Air Compressor Cycling Frequently
Discussion in 'Trucks [ Eighteen Wheelers ]' started by billandlori, Mar 3, 2012.
  1. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    My air compressor is cycling every 2-4 minutes while going down the road. More frequently when pulling a hill. The air compressor intake is from the pressure side of the turbo.
    No audible air leaks when truck is off, air stays up when truck off.
    Where should I start? Compressor Governor/Unloader, or compressor valves sticking? Air dryer?
    Thanks for the advice!
    Bill
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Check the purge line from the air tank to the govner a lot of the time the line leaks and also the same for the air line from the fan selinoid to the fan hub and check the main air line to the compressor outlet spray them with soapy water it can also be the unloader or the air govner
    billandlori Thanks this.
  4. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    you may want to check the wastegate actuator on your turbo too.
  5. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    Engine off, chock your wheels and release your brakes, and listen to rule out a bad brake chamber.
  6. HISPEED428
    HISPEED428 Light Load Member
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    I'd change the governor on the compressor first, mine was doin the same thing and that fixed it.
  7. billandlori
    357
    107
    Sep 5, 2010
    Thanks! It does it when I'm stopped and idling too, I've applied tractor and trailer parking brakes and dumped the suspension too and it still cycles the same.
    Bill
  8. billandlori
    357
    107
    Sep 5, 2010
    Sounds good, I think I'll give that a try.
    Bill
  9. rollin coal
    rollin coal Road Train Member
    13,108
    25,992
    Mar 29, 2008
    TN
    Fan clutch could be leaking. I had this problem and it was leaky fan clutch. Wont leak with engine off. Unhook air line and pressurize it with shop air to check for leaks.
  10. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    Unloaders in the compressor is the usual culprit.
  11. rollin coal
    13,108
    25,992
    Mar 29, 2008
    TN
    One thing about fan clutch leaks, this will also cause your engine fan to run constantly with a CAT.. forgot about that when I was posting earlier
    NadeauTrucking Thanks this.
