Pretty cold here this morning, down in the teens, but thought I would try and start our '94 Peterbilt with the Detroit motor. Surprisingly, started right up! Only problem, air compressor kept "popping". Do you imagine moisture was causing this? We didnt let it run long, but did bleed the air tanks when we shut it off. Son was going to maybe haul some grain later this week, and the truck has been setting since christmas, so thought I would see if it would start. He did buy some type of alcohol mixture for the brake system, but hasnt added any yet.
thanks,
coadman
air compressor in cold weather?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by coadman, Jan 4, 2010.
Possibly you had ice form blocking a line that caused the compressor head gasket to fail.
We had a Kenworth do this. the driver thought he blew up the compressor. Lol
Turns out there was ice in the air dryer, so the blow off kept "popping" off on the compressor. I took a heat gun and warmed up the dryer (takes a few minutes)and that fixed the problem. (I had also put in alcohol) Now we are getting the dryer fixed/replaced.
Cold weather and moisture in the air can be a problem. -
I'm thinking that is the problem. I will check it out more tomorrow.
thanks!
Jim -
There is probably ice in the line between the compressor and the dryer
take the line off at both ends. pour air brake antifreeze in the compressor end re connect it and spin the engine over to presurize the line you don't need to start it let tit sit a while and spin it again watch out for chunks of ice comming out of the dryer end. you shouldn't run anti freeze thru the dryer it clogs the dessicant pack.
