Air compressor issues
Discussion in 'Experienced Truckers' Advice' started by Mmorales95, Jul 23, 2020.
  1. Mmorales95
    Mmorales95 Bobtail Member
    5
    I have a 2007 kenworth t600 and just recently my air compressor has been messing up. It’ll work all shift then randomly I’ll notice I’m not holding air pressure. I pull over and both my tanks drop below 50 psi. I’m not able to build any air, I’ll sit for a couple of minutes and then I will start building air pressure again. Thoughts?
  3. flood
    flood Road Train Member
    4,168
    4,045
    Dec 25, 2010
    Governor...?
    jbatmick Thanks this.
  4. thejudges69
    thejudges69 Light Load Member
    246
    314
    Aug 22, 2015
  5. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
  6. TripleSix
    132,902
    Easy fix. If one of you guys don't mind, could you walk @Mmorales95 through installing and setting the air governor up to pop off at the desired PSI?
  7. thejudges69
    246
    314
    Aug 22, 2015
    Depends on what type of governor. The older ones are simple, a 6 year old could do it. The newer ones I understand are a little more involved.
  8. thejudges69
    246
    314
    Aug 22, 2015
    Oh and don't set it til it's installed and pumped up. If it stops pumping around 120-125 don't touch it. Never adjust them until you see where they are set at. The governor is either on your air dryer or on your compressor. Again don't touch the adjustment screw until your dryer unloads and see what pressure your at.
    Rideandrepair Thanks this.
  9. AModelCat
    162,672
    Typically its the governor sticking but I have seen the drier purge port stick open and leak out all the air as well.
  10. Ridgeline
    22,675
    121,462
    Depending on the governor manufacturer, you may have to use a different pilot port.
  11. xsetra
    xsetra Road Train Member
    5,182
    7,123
    Aug 21, 2011
    I've had similar issues with the unloader valve. N14 compressor. Also an easy fix.
    It's the part between the governor and the compressor.
    Most likely the governor. Those go bad more often.
