Air compressor issues
Discussion in 'Ask An Owner Operator' started by Winter Fox, Feb 18, 2021.
  1. Winter Fox
    Winter Fox Bobtail Member
    27
    6
    Nov 19, 2018
    Hi there, I have air compressor thats overcharging, especially on idle. Any ideas what could be a problem?
  3. 77fib77
    77fib77 Road Train Member
    11,431
    74,672
    Jul 7, 2010
    St Louis
    Its 18 bucks
    Your air governor. its cold, water could have gotten into the lines too.
    rolls canardly and 86scotty Thank this.
  4. Winter Fox
    27
    6
    Nov 19, 2018
    Thats was my first thought, so I went ahead and replaced governor,but it’s still doing same thing.
  5. 77fib77
    11,431
    74,672
    Jul 7, 2010
    St Louis
    Did you change the set screw to see if it would cut out a lower pressure, In the governor???
    rolls canardly Thanks this.
  6. 201
    201 Road Train Member
    12,653
    26,002
    Apr 16, 2014
    high plains colorado
    Air dryer froze?
  7. rolls canardly
    rolls canardly Road Train Member
    1,624
    3,972
    Feb 7, 2009
    mt. pocono. pa.
    Yes,
    u changed it,
    but there is a setting you can make lower,
    It takes the pressure on the incoming port and restricts it.
  8. Joyce's Volvo
    Joyce's Volvo Light Load Member
    116
    153
    Jun 28, 2016
    Pressure line from tank to governor restricted , may be ice, take line loose , you should air flow from tank . The other line goes to air dryer to make it cycle.
  9. Winter Fox
    27
    6
    Nov 19, 2018
    On my governor it says non adjustable. Should I get different governor with adjustable option and maybe try to adjust that way ?
  10. Winter Fox
    27
    6
    Nov 19, 2018
  11. Winter Fox
    27
    6
    Nov 19, 2018
    Ok thanks I’ll check that too.
