Air compressor stopped working. Where's the nozzle that lets you manually blow air into the tanks?
Discussion in 'Questions From New Drivers' started by DirtyhandsMcgee, May 3, 2018.
  1. DirtyhandsMcgee
    DirtyhandsMcgee Light Load Member
    71
    79
    Oct 30, 2017
    I just need to lift my brakes to make it a Mile down the road so it should only take about ten minutes. I did a innertube for my little cousin one time in under 5 minutes.
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Right here on the frame rail on the driver side. You need the right adaptor but the back side is usually push lock so you can disconnect it and splice into the line. It should fill both tanks.
  4. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    If the air compressor quit working there is no air to blow into the tanks.
  5. xsetra
    xsetra Road Train Member
    5,161
    7,092
    Aug 21, 2011
    Just cage your cans
    Don't think I would drive with no brakes.
  6. some other trucker
    some other trucker Light Load Member
    58
    64
    Apr 23, 2018
    Might be able to connect your redline to a second trucks redline.
    Both trucks release trailer brake valves and 2nd truck , while running, should be able to fill both trucks tanks as one closed system
    x1Heavy, Tb0n3 and Farmerbob1 Thank this.
  7. Ridgeline
    22,607
    120,076
    CALL ROAD SERVICE
    DONT TRY TO DO SOMETHING THAT YOU HAVE NO IDEA OF WHAT YOU ARE DOING.
  8. GreenPete359
    GreenPete359 Road Train Member
    2,167
    5,128
    Oct 21, 2017
    Driving my recliner
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    Sorry, I couldn't help myself. This is the only manual inflation valve I could think of.
  10. TripleSix
    132,255
    Do not move that truck without air! You wont have anything!
    shogun Thanks this.
  11. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Whuddaya need brakes for? All they do is slow ya down!:D
    06driver and xsetra Thank this.
