air dryer purge valve
Discussion in 'Freightliner Forum' started by JAYRODPA, Oct 26, 2014.
  1. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    purge valve not shutting down until I hit the brake or pressure drops to 110. replaced: entire air dryer, governor and air lines, unloaders. no change. found a pin hole in the storage tank. does anyone know if that could cause it ??????????
  3. Bendix Tech Team
    Bendix Tech Team Bobtail Member
    34
    23
    Jul 15, 2014
    is the purge valve fluttering or is it a constant dump of air pressure? also what air dryer do you have? troubleshooting varies a little from model to model
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be bad unloader valve,air flows via control line from compressor to dryer
  5. chimbotano
    chimbotano Heavy Load Member
    763
    1,101
    Apr 21, 2013
    I'm having almost the same problem with FTL 05 Columbia. I did not have pressure at all, I found out that the air hoses were plugged with oil/grease.
    I changed the hoses, the governor and the air dryer valve(kit)
    apparently it fixed the problem, however the constant air dump goes for a long period of time, which it never did before.
    Now the air pressure reach up to 125psi then it releases a constant dump of air down to about 110psi, the pressures back up to 125psi and the cycle start again.
    does anyone have any idea why the air dryers dumps the air little by little ??
    thank you for your time.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Do you know what kind of dryer it is? If it's a Wabco SS1200, it may have a regeneration valve. If it does, it will give a quick burst when it purges, then you get a light purge for around 30 seconds. If this was not the original dryer type, the wet tank may not have enough volume to complete the regeneration, which drops pressure enough to load the compressor and start the cycle over again. To fix it, Wabco has a pressure sensing check valve that replaces the check valve on the secondary air tank. Above 90 PSI, it is no longer a check valve, so air can flow back into the wet tank. This give the dryer more air volume for the regeneration cycle so pressure in the wet tank wont drop below governor cut in pressure.
    BoxCarKidd Thanks this.
