air dryer pops off every 20 seconds just replced it and the governor no leaks from gov to air dryer no water in tanks but each time it purges water is coming out please help!
air dryer
Discussion in 'International Forum' started by sjeffery, Sep 14, 2012.
Unloaders leaking in the compressor.
sjeffery Thanks this. -
how hard is this to replace or do i have to replace compressor
depends on your compressor, bendix the repair kit is about 15 bucks and 10 minutes to fix if it is the unloaders
i beleive it is cummins compressor and where is the unloader valve located thanks
If you have an ISX you must replace the compressor cylinder head. What engine do you have? Do you know your engine serial number?
79138070 isx 435
Yep, if the unloaders are leaking, you will need to replace just the head of the compressor. The unloaders are not serviceable separately.
sorry about that trying to do too much at once i have 2006 international 9400i isx cummins
