Air fittings...which one?
Discussion in 'Ask An Owner Operator' started by gekko1323, May 4, 2025.
  1. gekko1323
    gekko1323 Road Train Member
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    Hey guys. My mechanic told me to get him some 3/8" union air fittings. We had replaced a leaking leveling valve. So, I'm getting ready to order them and I'm bamboozled with the choices. Should I get the plastic ones or brass? Are there any specific specs I need to look for? Besides the truck stop and the dealer, is there any particular store you guys get them at like NAPA or Autozone? Any specific brand? I usually get the minor stuff on Amazon, but there are so many choices I just want to make sure I get the right stuff. I saw some great fittings kits and o-ring kits on there too. Thanks.
  3. Arctic_fox
    4,374
    23,850
    Sep 16, 2016
    TBH unless there is a spec listed in specific in the manual or a good reason to use plastic i always use brass. Lasts longer usually in my experince.
    Also this is the kit I use. https://www.kljack.com/products/ask...artVFCfUfzRMEuK3_UIKXYhy5tcS81EgaAuDiEALw_wcB
    Its a LOT more expensive then the amaxon kits but the amazon ones are cheap for a reason and i always regret using their crap. These ones ive had exactly 1 fail on me in 4 years.
  4. gekko1323
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    Great! Thanks for the input. And you weren't kidding about your kit.
    Siinman, Rugerfan and Bean Jr. Thank this.
  5. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,944
    Oct 31, 2023
    Brass is better. Plastics can crack and leak. Once you tighten a brass fitting down the compression guarantees a leak free connection. Those PTC fittings might be convenient in a tight place where getting a couple wrenches in is not possible but they're band-aids.
  6. Ridgeline
    22,636
    120,604
    Just an fyi … fittings have to be DOT fittings, napa has them.
    Siinman, Oxbow, D.Tibbitt and 2 others Thank this.
  7. 201
    201 Road Train Member
    12,635
    25,955
    Apr 16, 2014
    high plains colorado
    Several years ago, I went to a hardware store, and asked for 3/8 union compression fittings, and the dude said, unless they are used for non-automotive applications, he couldn't sell me one. :dontknow:
    D.Tibbitt and gekko1323 Thank this.
  8. Big Road Skateboard
    6,721
    37,838
    May 2, 2021
  9. abyliks
    abyliks Road Train Member
    4,019
    9,468
    May 2, 2010
    ludlow MA
    Brass compressing fittings, but I do have one of those plastic assortment kits for a just in case thing
  10. D.Tibbitt
    153,285
    Because anything on a truck has to have a dot stamping on jt
  11. Siinman
    Siinman Road Train Member
    5,455
    14,025
    Mar 5, 2017
    Kansas City, MO.
    Vampire, FloridaRetired and gekko1323 Thank this.
