Air foils on trailers?
Discussion in 'Questions To Truckers From The General Public' started by BigolBear, Aug 10, 2011.
  1. BigolBear
    BigolBear Bobtail Member
    10
    8
    Jul 21, 2011
    Aurora, Il
    First I just want to say thank you to all the drivers out there runnin the roads. Ya'll keep the country goin, I have nothin but respect for ya.:biggrin_25514:
    I've been noticin in the past year or so runnin between Chicago and North Carolina that more and more trailers have these air foil things on both sides underneath. I'm assuming they are for better air flow and fuel milage. Is this correct? What are your guys opinions on them? Do they make a difference?
    Thanks Bear
  3. DocG
    DocG Light Load Member
    186
    72
    Dec 14, 2010
    Florida
    They don't make much difference. The main reason the big carriers get them is to be a Smart Way certified carrier.
  4. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    They also keep fast and furious wannabes from thinking they can zoom under my trailer lol
    corneileous Thanks this.
  5. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    Replacing 150 trailers in our fleet brought our fleet average up 2/10 of a mile. That was appx 30% of fleet. Now we have new motors and trucks coming online so we are not getting valid results however in my truck pulling a load I had done 100's of times I was gaining almost 4/10ths by the fill up math which could be off because of temp, ground level........
    They also help in the wind. Seems like they would be less stable but I found they actually handled better.
  6. BigolBear
    10
    8
    Jul 21, 2011
    Aurora, Il
    See I would have thought that they would make it worse in a cross wind. Shows what I know! :biggrin_2559:
  7. Tazz
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    I thought so too. Of course I studied cows not aerodynamics. Has to be something whith cutting the cross wind out from underneath if I had to guess from the water spray in a Florida thunder boomer.
  8. Rascally Road Warrior
    Rascally Road Warrior Light Load Member
    207
    115
    Jul 23, 2005
    Titusville, FL
    In addition to these panels under the trailers, I have noticed these tent looking contraptions installed on the rear of trailers installed over the trailer doors. So far I have only noticed them on schnieder trailers.
  9. okiedokie
    okiedokie Road Train Member
    12,608
    95,364
    Jun 13, 2011
    PNWET
    Creates a negative ground effect just like race cars. Sucks the trailer downward and does not allow wind positive pressure to get underneath causing lifting.
  10. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Mesilla Valley Transportation here in El Paso uses those boat tails.
  11. seabring
    seabring Road Train Member
    1,844
    1,882
    Apr 24, 2011
    I agree that they dont make a huge difference on one truck pulling them but i think the little difference they do make would add up to a noticeable amount with a large fleet all pulling them. I noticed that the newer hard plastic type make a more noticeable fuel saving than the older aluminium type did.
