Air intake melting at turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by yj bill, Aug 18, 2016.
  1. yj bill
    yj bill Bobtail Member
    13
    What might cause the plastic from the air intake to start to melt where it clamps on the the turbo? It's on a Freightliner M2 with a Cat C7. The turbo was replaced about 1300 miles ago in SoCal and just driven through the Colorado Rockies. It's not melted through but looks like it got very hot in the area where it is nearest the exhaust manifold.
  3. 1fixitman
    1fixitman Light Load Member
    68
    14
    Aug 16, 2016
    Turbo cooled and lubricated by oil and air from the engine fan. Oil is cooled by your radiator and water pump. Did you notice your oil temp or coolant temp very high while driving those miles? I would look at your fan clutch very close or the solenoid that controls the air to it also. If there was enough air flowing thru the engine bay then it would cool it sufficiently. Will your fan lock up or does it free spin wether you have air supplied to it or not?
  4. yj bill
    13
    Water temps seemed normal. The fan starts at 200*.
  5. 1fixitman
    68
    14
    Aug 16, 2016
    The fan turns on but does it lock up with the engine side good or is the clutch worn real bad and it just slips a lot of the time? Turn engine off with air applied to fan clutch and ignition turned on. Is fan locked up with engine? Now remove air from the fan clutch...is fan locked up with engine? Does it spin easily in both conditions? If spins easily both conditions time for new fan clutch. Detroit in a Volvo that fan clutch was 600$
  6. yj bill
    13
    Did check it this morning and the fan clutch seems to be working as normal. Thanks for the reply though.
  7. 1fixitman
    68
    14
    Aug 16, 2016
    Only other option I can think of is to check your air filter. If you do not have good air flow to your turbo you will choke your engine, get less fuel economy, less air flow to the cool side of the turbo. If that is not it then you need to install a modified heat shield between your manifold and your turbo to mitigate that heat away from your new turbo. I am just giving you logical solutions to try to solve your problems to help you out. Good evening.
  8. yj bill
    13
    Someone on another venue suggested that the wastegate may not be opening as it should. The boost reading on my scan gauge has been jumping around. This has been going on for a while and I just ignored figuring the scan gauge read was bogus and the truck was running good. And no check engine light or derate.
  9. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    Plastic? On a turbo connection? Good grief, that doesn't sound right considering how hot a turbo gets.
  10. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Yep, Freightliner did it on big bore engines for a few years as well. As far as turbo getting hot, check air cleaner like someone stated and for any leaks in the intake system. A lot of C7's utilized a "smart" waste-gate that could cause issues as well. If I remember right the solenoid was on the left rear corner of the block, real easy to access! LOL
    John Forehand Thanks this.
