Air issue, loosing air while parked.
Discussion in 'Ask An Owner Operator' started by dphillips, Sep 5, 2017.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a 2007 Cummins ISX Volvo and when I'm parked just idling I noticed my air pressure drops down to about 90 95. lt'll build air as soon as I start driving and I hear the air dryer kick in but I'm not seeing or hearing in the air leaks at least while it's off I just changed the air dryer about 2 months ago where should I look.
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Soapy water and start putting on all air fittings,,,, try the air tanks first.
    dphillips Thanks this.
  4. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Ive been chasing 1 for a few years- Mine is even more difficult- I lose air ONLY when Im Driving-The Red needle ONLY, Standing still both buttons in-Not a single Hiss-
  5. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    air leveling valves can bleed thru the lever shaft. if you leave the trailer supply pushed in check the gladhand seals,they get cracked and flattened.
  6. shogun
    shogun Road Train Member
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    Fittings under the dash that goes in the splitter, fittings at the air tanks, fittings at the air bags is common in Volvos.
  7. Ridgeline
    22,636
    120,647
    Try your parking valve.
  8. Goodguy88
    Goodguy88 Medium Load Member
    470
    139
    May 8, 2017
    Do a audible airleak with truck off
    Wheels chalked
    Have someone help you so you can walk around truck
    . have some water and soap mixed in bottle handy
    Lepton1 and dphillips Thank this.
  9. dphillips
    82
    8
    May 14, 2013
    when I cut the truck off there's no audible leak. I spoke to a mechanic who said he just had that same problem and it was the air dryer cartage I just changed that air dryer 3 months ago would it need to be changed already. Also how can you tell when it's time to change the cartage
  10. shogun
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    Air cartridge is typically a yearly maintenance item. Make it a point to drain your tanks a couple times a week and look for moisture in your hand when it sprays. Pay special attention to the type of moisture, does it smell like oil, water etc which depending can be an indication the seals on the compressor are starting to leak.
    Leopard and dphillips Thank this.
