Air Leak 2016 Cascadia
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OTR--247, Apr 7, 2025.
  1. OTR--247
    OTR--247 Bobtail Member
    44
    24
    Apr 27, 2010
    La Luna, Valencia
    After 12h this is what gages show
    Any advise where to look, color line?, S stand for service and Secondary reservoir/system?.
    Unrelated: A one tap from a 1/2 pound hammer fix my fan clutch!!!
    Honey, Honey I fix it!!!
    What, how?
    Well Honey is complicated.
  3. JB7
    JB7 Heavy Load Member
    953
    1,646
    Dec 13, 2022
    Laurel, MD
    S stands for Secondary which is for the front brakes. P is for Primary which is for the rear brakes. Normally each has their own air tank and a line going from each tank to the foot/treadle valve. I would spray some soapy water on the bottom of it to see if it is leaking. Trace the lines from the front brakes back to the tank and any lines leaving the tank. There is a check valve at the entrance to both the primary and secondary tanks.
    OTR--247 Thanks this.
  4. OTR--247
    44
    24
    Apr 27, 2010
    La Luna, Valencia
    Just came back from buying a Y pushing connector that goes in the engine compartment driver side by the firewall (3/8 red lines). S pressure went down to 0, P pressure just like in pic, no movement. Got another small leak in the valve red line that connects trailer air line and another one in the supply port of the air dryer, witch i guess shouldn't be the problem cus the check valve in the tanks.
  5. RunRunCrew
    RunRunCrew Bobtail Member
    Dealing with this same problem right now. Lost air pressure fan clutch not cooling engine. Was told my compressor is bad
  6. OTR--247
    44
    24
    Apr 27, 2010
    La Luna, Valencia
    Sorry.
    Check for mayor air leak
    Check for air inlet to compressor obstruction.(hose to air filter)
    Check for air outlet obstruction.(hose to dryer)
    Check governor.
    Then go for the compressor. I can't even see mine with a flashlight parked in my backyard!.
    Fan clutch won't engage if there no air pressure.
