Air Leak from Truck Height Control Leveling Valve Normal?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jul 5, 2019.
  1. PE_T
    PE_T Road Train Member
    So we all get some air leak through it when we’re getting loaded or unloaded, but how much air leak is too much? I sometimes have to air up my tanks right after loading/unloading. Should I be worried? I don’t remember the last time the height control leveling valve was replaced. This is on a 2014 Freightliner Cascadia DD15.
  3. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Sounds normal to me. It's always purging air when getting loaded or fighting to supply air are when you are getting unloaded. I don't think they are required to compensate for such drastic changes.
    Wait until after the job is done and then do an "air test" to see if it's acceptable.
    Rideandrepair and PE_T Thank this.
  4. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    Leaking when being loaded/unloaded it normal..
  5. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    Depends on where its leaking from? Break out the soapy water. Wiggle the lever and watch for leaks where the shaft enters the valve and all the fitting and air line joints. The only place leaking should be present is from the exhaust port during leveling out, as allready mentioned which is completely normal.
  6. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    When you do your "leak down test" during your pretrip how
    much air pressure do you lose?
    PE_T Thanks this.
  7. PE_T
    I must admit I haven’t done it for months now, but my air leaks overall are mostly under control as I fix them all myself. I usually just wait until my air tanks are continuously under 75 PSI after a 10-hr break (both breaks set) or under 75 PSI after 30 min to a few hours (trailer breaks released). I am aware this isn’t the official test.
    Rideandrepair Thanks this.
  8. rcelmo
    459
    1,986
    Mar 23, 2015
    Sounds like everything is fine. Since the leveling valve is connected
    to the air bags "obviously" it is normal to hear air leaking during loading
    and unloading. As long as the truck isn't leaking a significant amount of
    air I would not worry to much about the leveling valve.
  9. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    If it’s not leaking otherwise, except for loading and unloading, than it’s normal.
    PE_T Thanks this.
  10. Rideandrepair
    17,349
    56,291
    Aug 8, 2015
    The problem I’ve had, is an old valve will tend to stick and seep, sometimes intermittently, taking a long time to settle. I had a DOT ask once, “ What’s that leak, leveling valve?
    PE_T Thanks this.
