Air leaking out of this connector even after replaced.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Shotgun94, Apr 25, 2019.
  1. Shotgun94
    Shotgun94 Medium Load Member
    460
    316
    Sep 24, 2017
    Georgia
    It leaks out or the sides where that torch screw holds in the seal when I set the brakes air will blow put but then stop after some time.
    When I push in the brake buttons it will make a noise for a little longer then usual.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    Hook up to a different trailer. What does it do?
  4. Shotgun94
    460
    316
    Sep 24, 2017
    Georgia
    I use the same trailer.
    Maybe I'll test that sometime.
  5. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    Bad brake chamber on the trailer.
    Heavyd, Hammer166 and Intothesunset Thank this.
  6. Shotgun94
    460
    316
    Sep 24, 2017
    Georgia
    I didn't hear any air leaking. Could I still have a bad chamber?
    Sounds like this is common.
  7. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    If I remember last I had this problem it was a broken spring in a chamber. And an air leak from transmission air servo line fitting.
  8. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    Your description of the problem is not complete. What happens when you push in the red knob? What happens when you pull the jonny bar? Those are quick release valves. Which one leaks red or blue?
  9. Shotgun94
    460
    316
    Sep 24, 2017
    Georgia
    Well, when I push in the trailer brake and release it the air noise will linger longer then it used to.
    I also hear some are inside of the cab of the truck after both brakes are set.
    Those fitting in the picture. The old one doesn't have any air pressure when I took it off. The old one is causing the issues. I had changed it out with a new one and later on, it leaking again!.
    So I put on the other good old one in its place to see if perhaps a faulty part. Well later on it does it again!
  10. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Replace the used valve with a new one. Sounds like a bad diaphragm.
    I thought those are called tractor protection valves.?
  11. AModelCat
    161,298
    Thing most people overlook when diagnosing air systems is a lot of valves tend to have their exhaust open to atmosphere when they aren't being used. A lot of times its an air system component upstream or downstream of the leaking part that has failed. It just leaks out the open exhaust port because its the easiest place for air to escape.
