Air lines and wire loom
Discussion in 'Ask An Owner Operator' started by Hayfieldmn, Mar 21, 2021.
  1. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    Had a bit of chaffing on a ABS wire on my steer axle, replaced sensor then ran new sensor in wire loom and zip tied it to the air line for front brakes, is it legal to have it zip tied against rubber air line or you think DOT will have a fit??
    Thanks
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    150,789
    Ya if you dont have anything else wrong with ur truck i could see them writing u up for it
    Hayfieldmn Thanks this.
  4. Hayfieldmn
    158
    239
    Sep 10, 2016
    Maybe I'll find a way to keep them apart.
  5. D.Tibbitt
    150,789
    You might try a hose sepator. Not sure if u could get one small enough to fit the abs wire but i know dot wants to see this between ur hoses so they dont chaffe
    baha and Hayfieldmn Thank this.
  6. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    For your steer, the ones that were posted above are about right, just run the wire through a rubber hose thats the same diameter
    For double cans, look at these, dirt cheap and the wire runs through the small hole
    Final Drive, Hayfieldmn and D.Tibbitt Thank this.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    Wires and airlines are clamped and or zip tied to each other all over on a truck. There’s nothing they can say about it.
    TheLoadOut, shooter19802003 and lester Thank this.
  8. D.Tibbitt
    150,789
    Have u ever been written up for a chaffed airline that was zip tied together? Because i have... they want to see clamps on them keeping them apart , not tied together where they can rub.
  9. Oscar the KW
    12,246
    28,116
    May 19, 2011
    I never have. If they are zip tied well, (overdone) they can’t rub against each other to chaff.
    Hammer166, lester and D.Tibbitt Thank this.
  10. FLHT
    FLHT Road Train Member
    1,402
    2,466
    Aug 2, 2014
    An old length of garden hose works well with zip ties
    D.Tibbitt and Hayfieldmn Thank this.
  11. wichris
    wichris Road Train Member
    4,348
    8,752
    Jan 17, 2011
    Every new truck i've ever bought must have been able to be written up. Never had it happen but some here say it's so.
    TheLoadOut and D.Tibbitt Thank this.
