Other than a trailer shop is there a location you can buy these parts? I have a 2022 Utility 53 dry van and looking to get some spare parts.
Air Lines, Springs, and Connectors for Sliding Axle Drive Van
Discussion in 'Ask An Owner Operator' started by Siinman, Jun 8, 2022.
I ran into this recently on my 2017 Great Dane reefer trailer. You can get the bulk hose and fittings that connect the relay valves to the brake chambers at Truck Pro or the like. Cut the hose to the exact length and the fitting is a clamshell contraption that's not too hard to figure out. Same with the hangers and springs, sold at any decent truck parts dealer.
However, the hoses connecting the hard lines to the chassis had oddball sizes and fittings and I ended up getting them from the Great Dane dealer. They were actually priced reasonably, which was a surprise. Less than $70 for the pair if I recall. I did have to pick them up at the warehouse for same day. They weren't in stock at the dealer.Siinman Thanks this. -
The fittings on the hoses to the brake chambers are basically a threaded barb and a 2 piece interlocking collar with a locking sleeve that pushes on over it. You put the collar on the hose end and lock it, put some grease on the barb and twist it into the hose. It compresses the rubber when it goes in to form the seal. The brass piece fits an allen wrench used to thread it into the hose. The fitting kits come with the wrench included.Siinman Thanks this.
