Air not Building on a Freightliner Cascadia
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mikewillfixit, Mar 25, 2025.
  1. Mikewillfixit
    Mikewillfixit Bobtail Member
    5
    5
    Mar 25, 2025
    Hello, new to this forum. I have a concern with a 2015 Freightliner Cascadia. One of my Techs R&R the Air Drier w/ Air Governor and R&R the tank that the Air Drier mounts to. He thought there was a blockage inside the tank since its a 2 part tank. The truck isn't building Primary Air at all and building about 40-50 psi on the secondary. Air is coming out of the Air compressor > Air Drier and is building air in the wet tank portion of the air tank. ( The side of the tank that the Air Drier is mounted too. ) I'm not getting any air out of the green supply line from the Air Drier to the Primary Tank. What could be the problem. I pray it's not the unloader valve or anything to do with the Air Compressor with it being a pain in the back of a job.
  3. Mikewillfixit
    5
    5
    Mar 25, 2025
    * Fixed * Ended up hooking shop air directly to the Air Drier. And the truck builded 125 psi on primary and secondary. Which is telling me the air compressor isn't building air properly. I could've replaced the Unloader Valve on the Air compressor and fixed it but with the age of the compressor, we decided to replace the Air Compressor. ( Which comes with the new Unloader Valve. )
    xsetra and OldeSkool Thank this.
  4. OldeSkool
    OldeSkool Road Train Member
    1,796
    5,350
    Jul 17, 2018
    New Hampshire
    Glad you figured it out.
    Mikewillfixit Thanks this.
  5. Mr Bob
    Mr Bob Light Load Member
    262
    81
    Mar 17, 2015
    i hope you tested you compressor output hose for leaks with soapy water.
