Air pressure goes up to 140
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shawn19, Jun 3, 2020.
  1. Shawn19
    Shawn19 Light Load Member
    107
    29
    Apr 20, 2019
    I have a 2005 Columbia my air pressure goes up to 140 how do i ajust it to 125 i replace it with a new air governor that said it pre set to 125 still goes to 140 the governor is not adjustable anyone know?
  3. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    Most governors are adjustable. Screw off or pull black plastic cap, back off locking nut, turn set screw counter clockwise to lower pressure.
  4. Shawn19
    107
    29
    Apr 20, 2019
    This one doesn't have a adjustable governor i know what a adjustable governor is i adjust air pressure before on my previous truck.
  5. kemosabi49
    10,011
    41,498
    Jan 13, 2013
    SW Arkansas
    If it is not adjustable, then you could buy one that is adjustable and adjust it.
    AModelCat and baha Thank this.
  6. mslashbar
    mslashbar Medium Load Member
    594
    797
    Jul 22, 2009
    elizabeth,co
    Maybe it's not actually the governor that's bad, maybe your gauge is reading wrong.
    clausland Thanks this.
  7. SmallPackage
    4,524
    13,618
    Dec 20, 2019
    Marion Texas
    I was gonna say that but when someone brings up that possibility others tend to dismiss it as impossible to happen. Lol! We old timers know gauges don’t ever lie. Lol!
    clausland and AModelCat Thank this.
  8. AModelCat
    145,381
    Could be a blocked up signal line or port from the tank, a gunked up and sticking unloader piston, gauge not working properly etc.
  9. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    What's wrong with 140?
  10. baha
    baha Road Train Member
    4,137
    2,834
    Jul 25, 2013
    ga
    The Anti/lock brake sys.. needs more air to work like it should, so most of the new air reg. are set hi to make newer trucks brake sys. work, so you can run it the way it is.
  11. Shawn19
    107
    29
    Apr 20, 2019
    It not the gauge had the dash cluster replace an it reading the same it an older truck 2006 i drove 3 other Columbia like this one an they all run at 125
