Air pressure leak
Discussion in 'Experienced Truckers' Advice' started by Halfyank, Apr 17, 2017.
  1. Halfyank
    Halfyank Bobtail Member
    18
    8
    Dec 8, 2016
    I'm a company driver with a 2016 Freightliner automatic. Thursday before parking at a company yard, one that does not have any repair facilities, it seemed to me that I was getting a low transmission air warnings and my brake pressure was low much more often. It was low so I let it idle till it was at full pressure then drove about 30 minutes . When I stopped I shut down for maybe a couple minutes and when I started back up everything was low again. I can't recall it going low so quickly before. I've been at home without the truck but I'm heading back out tomorrow. Is there some stupid easy reason it could be getting low so fast that I could fix myself or should I head someplace for repairs?
  3. MachoCyclone
    MachoCyclone Road Train Member
    4,417
    3,907
    Jun 13, 2012
    Texas
    If I was a company driver, I would call breakdown and find out where they want it taken to. I would not work on company equipment myself. That could get you fired. Not mention you could void any warranty the truck my have.
    Also, you probably should have mentioned this to the company as it probably could have fixed while you were at home.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,136
    Jul 19, 2008
    Sioux City,ia
    What did the companies shop tell you?You being a company driver you need to get ahold of them ASAP.They'll probably send you to a Freightliner in your town.
  5. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Sounds like something you should be able hear if you can get somewhere quiet. Chock the wheels air it up good, release all brakes, put in drive, then turn it off and get out and start listening.
    May be something simple. Maybe not.
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Get a spray bottle. Fill it with water and a splash of Dawn dishwashing soap. Spray down the hoses and connectors. Leaks will bubble. If you can hear the leak, but can't quite find it, a length of rubber hose works well as a stethoscope.
    I'm guessing you have something fairly major give out. Something like a blown cab air bag (the two small air bags at the back of the cab).
    v.keen, Cottonmouth85 and DDlighttruck Thank this.
  7. Halfyank
    18
    8
    Dec 8, 2016
    Thanks for all the input. I thought it could be something like a loose shuttle #### but sounds much more than that. I'll keep a very close eye on it when I pick up the truck tomorrow and probably call roadside right away.
    Lepton1 Thanks this.
  8. AhkTheTrucker
    AhkTheTrucker Bobtail Member
    10
    5
    Oct 29, 2017
    Philadelphia
    I just had the same problem. Same year & model.
  9. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Seems like the lines going to the transmission leak alot. And if it's not that they run alot of the air lines up over that transmission where it's hard to get at anything.
  10. ChaoSS
    3,338
    6,755
    Sep 20, 2014
    I know this is a bit old, but is that your truck?
    Whoever invented push lock air fittings, or perhaps whoever decided that they have a place on a truck, should suffer a miserable death. Just my opinion.
    Lepton1 and kemosabi49 Thank this.
  11. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I agree on the push lock fittings. Next to useless.
    That picture was from the Freightshaker Century Classic I used to drive. I now own a KW T2000, the one with the nice stainless steel bumper...you know, lipstick on a pig.
    ChaoSS Thanks this.
