Air pressure problem
Discussion in 'Mack Forum' started by Jhuls41, Feb 28, 2016.
  1. Jhuls41
    Jhuls41 Bobtail Member
    6
    I am having trouble with an 07 with the 427 asset. It will not build past 40 psi and it's slow to get to that. I also put a new reman compressor on last November but realize it could have an issue already. No air leaks at all. Interested in people thoughts thanks. Drier isn't bad bypassed it still the same issue.
  3. pigeon river trucking
    pigeon river trucking Light Load Member
    132
    99
    Jan 1, 2016
    michigan
    Sounds like it could be air governor
  4. dgc
    dgc Light Load Member
    92
    46
    Dec 2, 2012
    miami, fl
    Yup sound like the air governor
  5. Jhuls41
    6
    Replaced governor still same Problem
  6. dgc
    92
    46
    Dec 2, 2012
    miami, fl
    When you replaced the compressor you had to switch everything over, the compressor should also have a pop off valve, Have you checked it to make sure its working properly?
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Soap, water, spray bottle. Start spraying.
  8. AModelCat
    162,693
    Could be the check valves or unloader piston sticking.
  9. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    try changing the 4 way protection valve this is most likely your problem looks some what like this down below
    disconnect the little line going from the drier back to the compressor that turns the compressor on and off
    try squirting a little CRC in the intake of the compressor while running 56251-Supply-Truck-Brakes-4-Way-Circuit-Protection-Valve-1.jpg
