I have 06 Columbia with a c15 my air pressure goes up to 140 before purge I replace the governor it not adjustable it a pre set governor at 125 why isn't it purge at 125 ?
Air pressure purge at 140 psi
Discussion in 'Trucks [ Eighteen Wheelers ]' started by D2020, Nov 25, 2020.
Did the old governor purge system at 140 also?
Could be your dash gauge isn't accurate. -
Old governor did the same thing that why I replace it would not do it all the time now it does getting worse an it not my dash gauge had that replace.
What is getting worse?
I have an older truck. My top pressure is around 135. -
sounds normal
There is a plate on top of the compressor that has the unloader-valves in them. You have to buy the kit and replace them(o rings etc). Easy fixed. Make sure you get the right kit. I believe they have 2 different ones. I removed mine first and took it the parts house to make sure they had the correct one.
Reason for edit: Correction.... -
I believe @Diesel Dave is referring to unloader valve.
haycarter and Diesel Dave Thank this. -
Torx bit for compressor on ACERT motor.
