What’s going on drivers.
Woke up this morning and my air pressure won’t go above 70. Also I’m driving a 10 speed freightliner cascadia and when I flip from Lo to Hi, the truck won’t switch so I can get into 6th gear. Need some help. Are my lines frozen?
Air pressure won’t go above 70
Discussion in 'Questions From New Drivers' started by Drama304, Dec 14, 2020.
Sounding like you're froze up. The Lo to Hi issue also points at frozen lines. What's the outside temp where you're at right now? Is there air pouring out of the bottom of the air dryer or anywhere else?
You are driving with low air pressure?
seriously?ZVar Thanks this. -
At least I hope so. -
Considering the vast majority of trucks don't allow air to flow to accessories until approximately 90 PSI, your only issue is an air buildup problem. 99.9999999% chance there is no issue with the transmission.
