Air problems 2001 peterbilt 379
Discussion in 'Peterbilt Forum' started by Jempy, Apr 5, 2017.
  1. Jempy
    Jempy Bobtail Member
    so I got air leaking out the exhaust port on the fire wall when pushing on the brakes. I changed out the dash valve,treadle valve and also checked all my brake cans to make sure all the diaphragms were good by taking of the air lines and plugging them one by one. Anyone have advice on where to go from here. Also if u pull the johnny bar down it blows air out the exhaust port on the treadle valve.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,483
    6,526
    Aug 26, 2014
    You are moving right along there! Yes I have done that sort of thing also. Try to find the problem first and then replace that part. I would look toward something like the tractor protection valve, I saw that on a White GMC without a trailer hooked up. Check to see if it is back feeding through the hand valve. I then traced it to the valve in front of the coiled trailer air lines. Let us know what you find and or ask more questions.
  4. Rat
    Rat Road Train Member
