air pump purging air-Detroit 60
Discussion in 'Trucks [ Eighteen Wheelers ]' started by longbedGTs, Dec 15, 2008.
  1. longbedGTs
    longbedGTs Heavy Load Member
    974
    717
    Texas
    Im currently broke down in Minnesota and Ive lost nearly all air pressure due to the air pump purging air. Breakdown says the lines are frozen, which sounds right since its about 5 deg now. I dont have enough alcohol that would make a difference. Is there anything I can do to get this thing to stop purging air? Its coming from a little brass valve on the top of the air pump. Thanks and if anyones running by exit 69 WB off I495(St.Paul), I could sure use some help. Thanks!
    **been waiting on service truck for 3 hours**
  3. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    That sounds like a bleed valve.
    Can you pull on the stem and see if you can purge out the ice/dirt?
    Lilbit Thanks this.
  4. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    you've got a blockage somewhere between the compressor and the dryer. only way to clear it is alcohol or heat. pull the line off and pour alcohol down it, a good bit of it!
    before I head into weather like that I always pull a line and douse it in alcohol.
    You have anything else that doesn't freeze? some engine coolant mabey?
  5. 24valve puller
    24valve puller Medium Load Member
    399
    89
    Sep 8, 2007
    N.E. Oh
    Mine did this last year, luckily I was just leaving the farm. Safety pop off valve on the back of the compressor kept popping at like 75psi, got the truck in the shop and thawed everything out and it still kept doing it. Ended up replacing the pop off and all was good, I should say mine was on a cummins though, not sure how the system is on a detroit.
  6. longbedGTs
    974
    717
    Texas
    Ugh! What a fun day this was! After a tow to the shop, a few hours thawing with a bullet heater, and 1 lost day, the truck is back to normal. Its supposed to get to -15 tonight, so I will see if everything is indeed, back to normal. Im spending the night in the shops driveway!
    BTW, before the tow to the shop, the mech tried alcohol down the line coming directly off the pump. No dice.
    There were alot of trucks in that shop for frozen air lines, frozen batteries, or clogged fuel filters.
  7. Chain Drive
    Chain Drive Medium Load Member
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    remember to take lots of antifreeze in the morning and check her out good before you leave I found thawing one thing in a shop often froze other things because ice/snow melting inside and freezing outside
  8. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    That's why when it drops around freezing or below..Old Bull idles...Screw CARB......:biggrin_25510:
  9. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I'd rain all your air tanks, put more alcohol down that same line he did then pour a bunch into the trailer lines and hook them back to the trailer.
    if you have a fuel filter heater then make sure it's on
  10. 24valve puller
    399
    89
    Sep 8, 2007
    N.E. Oh
    I'm guessing that it is your truck? is it also your trailer? if it is then drain all the water out of the system when you get somewhere warm and put a new air dryer on. Should never have to worry about freezing up. with a new dryer there should be no water getting in the system, if you keep the lines to the trailer together and pluged when unhooked. Keep some alcahol with you but dont use it if you don't have to, the lines and valves on everything will thank you
  11. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    true, alcohol is hard on the seals. I say to douse it only beause you obviously have water in your system now
