Air release/air hissing sound when changing gears. Help?
Discussion in 'Experienced Truckers' Advice' started by Dave2014, Sep 22, 2014.
  1. Dave2014
    Dave2014 Bobtail Member
    24
    Jan 20, 2014
    I have a 2007 volvo 780 cummins engine. I've noticed an air hissing sound when I take my foot off the gas or in between gear changes as I try to pick up speed all the way up to 5th gear change. Has anyone had this problem? If someone could give me insight on this, that would be very helpful.
    Thank you,
    Dave
  3. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Check the hose from your compressor to your intake manifold...... Looks like a water hose
  4. xsetra
    xsetra Road Train Member
    5,107
    6,967
    Aug 21, 2011
    Is it coming from your shift knob. Lot of possibilities. Any of your connections could be the source,
  5. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Hearing it with the window up, down or both?
    Hear it at all while stopped? With splitter in either postion?
    Also check exhaust for leaks could be hearing the turbo down spooling since its between shifts or letting up.
  6. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    Bet your splitter is in the middle. Mine does that time to time. If in high gears take it up more and bet it goes away.
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,364
    7,733
    Jul 11, 2012
    in the bush somewhere
    Could be the cab suspension leaking off excess air, especially if you get'er rocking
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I had a similar noise with the D13. Turned out that one of the EGR tube clamps broke, letting exhaust leak out.
