#### air releasers
Discussion in 'Questions From New Drivers' started by Slargtarg, Sep 8, 2017.
  1. Slargtarg
    Slargtarg Light Load Member
    134
    191
    Apr 28, 2015
    So some guy just parked in the slot next to me.
    Very loud air releases every 5 seconds.
    Most trucks release air like this while idling occasionally, but this is ##### ridiculous.
    What the hell causes this to be this frequent and loud? I've seen this problem before in other trucks.
    Probably no sleep tonight.
  3. WesternPlains
    6,298
    53,294
    Sep 1, 2017
    There's a over pressure valve on the air dryer. It's bad. He shouldn't be driving. Should have it fixed asap.
    I'd move. It's gonna keep going until the air tanks are empty.
  4. Hulld
    Hulld Road Train Member
    2,883
    6,566
    Oct 19, 2015
    Upstate NY
    Air dryer blowing off every 5 seconds because the guy has an air leak and its over working the air dryer and the compressor.
    Hopefully his compressor will seiz up soon and shut the truck down so you can get some sleep.
    fargonaz and Tb0n3 Thank this.
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    the most common cause i have found for that problem is a leak on the signal line from the governor, basically governor thinks air psi is low so it kicks the compressor in almost as soon as it kicks in it hits governed psi so it kicks it back out witch signals the air dryer to purge. a bad purge valve can also be a common culprit
    fargonaz, Tb0n3 and Lepton1 Thank this.
  6. MACK E-6
    48,860
    226,262
    I developed an air leak on the trailer once not long after I left the yard, pretty bad, but not enough to make the truck undriveavable and not be able to do the run. I didn't hear the air dryer all day until after I dropped the trailer, at which point once the pressure topped out it spit out enough water and oil at once to cover a platter.
    Lepton1 Thanks this.
  7. DTP
    DTP Road Train Member
    1,281
    2,708
    Dec 9, 2014
    And of course these aholes every time can't shut the truck off for the night, never fails...
    12 ga, fargonaz and Lepton1 Thank this.
  8. Tb0n3
    Tb0n3 Road Train Member
    4,562
    9,080
    Oct 5, 2012
    Earth
    How are they supposed to sleep in 68 degree weather?
    fargonaz and DTP Thank this.
  9. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    yah,the truck needs batteries too.....
  10. xsetra
    xsetra Road Train Member
    5,111
    6,975
    Aug 21, 2011
    The reason it is so loud.
    You're parked too close to them. Haha.
    This is very annoying.
    Hope you got some sleep.
  11. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    It's part of the life, you are going to have to get used to it. Either move the truck, or stop parking at truck stops.
