Air ride valve on Volvo Vn
Discussion in 'Trucks [ Eighteen Wheelers ]' started by me myself and I, Dec 27, 2009.
  1. me myself and I
    me myself and I Heavy Load Member
    732
    312
    Oct 5, 2009
    vernon hills,Il
    Anybody can tell me how to adjust that thing?
  3. vegetto05
    vegetto05 Light Load Member
    95
    23
    Jan 5, 2009
    KC, MO
    front or back?
    can't adjust the front
    the back, you have a leveling valve behind your front rear drive axle. if you look, its mounted on a bracket, which is mounted on the frame. this bracket has only one bolt in it for a purpose, such that if you loosen it, turn the bracket, you will adjust your ride height.
  4. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    you adjust like he said in the first reply, but you need to call Volvo give them your vin number and they can tell you where to mesure and how high to set it, if you guess at it you could get a vibration in the drive line.
  5. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    not to mention, it might put you higher than 13feet 6 inches...
  6. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    if you get it too high the transmission, not kidding, will sound like it is coming out. almost all the whitegmc/volvo's i've had will do that. i have about 2 to 2 1/2 inches from the bottom of the bag to the bottom of the horn . rides well. johnny
  7. me myself and I
    732
    312
    Oct 5, 2009
    vernon hills,Il
    The way it was explained to me you can only adjust ride height by changing lenght of vertical rod connected to air ride valve arm. But if you try to adjust valve itself - like somebody I know tried to - you end up with new valve ...and bill for $ 250.
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    My '07 the valve went bad, was loose in the mounting, and was the real cause of the transmission noise I had.
  9. Rock hauler
    264
    54
    Nov 26, 2008
    Deridder La.
    When you change the ride height of the air bags you change the angle of the U-joint witch causes a vibration. It sounds like the trannys falling out, but the noise runs up the drive line to the shifter. You can have the carrier bearing in the rear diff. go bad and it sounds like the trannys going bad. you only have a few inches of travel in airbags so unless your trying to lose an inch to clear something or raise an inch to get over something theirs not much reason to change it. it dosen't make enough differance in the ride to make a differance, to raise it an inch dosen't move your load gauge hardley a needle wideth. Not trying to be a smart ___ ,but call the dealer with the vin number they will tell you how to measure it and you will be glad you did.
  10. jweems3
    jweems3 Bobtail Member
    My father was killed trying to level his truck. Do Not Do IT Yourself. This should be a RECALL on all Volvo trucks. The bar is to LOW on the back of thr TRACTOR!!!!
  11. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    I'm sorry to hear, may he rest in piece.
    However I have adjusted the ride height on my truck and no problems. You need to be aware of your surroundings
