Air Shift PTO
Discussion in 'Ask An Owner Operator' started by Oxbow, Dec 9, 2017.
  1. Oxbow
    Oxbow Road Train Member
    12,671
    130,692
    Nov 24, 2015
    We have two trucks that have wet kits on them. One we installed ourselves, and the other had the kit on since it was new. The one that we installed requires air to engage it, and the other requires air to disengage. They both work fine, but on these cold mornings the one that requires the air to be built up in order to disengage puts a load on the engine immediately until the air pressure builds up.
    I really don't like putting any load on a cold engine, so I just hold the clutch in until the air builds up.
    Was this done so that one would be warming up the hydraulic oil with the engine?
    Reason for edit: Sorry, posted this in the wrong section. Please feel free to move to the Garage Section.
    cke, snowman_w900 and SAR Thank this.
  3. Hulld
    Hulld Road Train Member
    2,882
    6,565
    Oct 19, 2015
    Upstate NY
    Not sure why one was plumbed that way but also remember when you hold the clutch down you are putting a lot of force on the thrust bearings on the crank shaft.
    Not sure if this is detrimental to the thrust bearings of a cold engine or not?
    Oxbow Thanks this.
  4. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Any idea what pto units you have on there? I think its strange someone would want air to release the pto, in my opinion
    SAR, wore out, Tb0n3 and 2 others Thank this.
  5. Oxbow
    12,671
    130,692
    Nov 24, 2015
    I believe the one that we put on is a Chelsea. I'll have to look at the other. It is on the 2000 KW that I bought this year, and has had a Reliance transfer dump bed on it since it was new. Reliance may have been the original installer.
    SAR, cke and snowman_w900 Thank this.
  6. Oxbow
    12,671
    130,692
    Nov 24, 2015
    I should be able to just change out the air shift portion I suppose. It would be bad to have a leak in the line while going down the road, and have the PTO try to engage.
    SAR, wore out, cke and 1 other person Thank this.
  7. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Well that's exactly what I was thinking too. I can't think of any real advantage. Be bad to have it try to engage at road speed.
    Only thing similar to that idea would be like a constant mesh option, but that's not shiftable. Those are for trucks that need live hydraulics like a snowplow or fire truck.
    I wonder how it's plumbed? Is it the shifter mechanism or perhaps they have the air plumbed into something like a kysor switch?
  8. Oxbow
    12,671
    130,692
    Nov 24, 2015
    I'm not sure. I'll have to investigate a bit.
  9. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    I have never seen a transmission PTO that used air to disengage and defaults to engage, I think the air solenoid is mounted backwards.
    SAR, snowman_w900, bigguns and 3 others Thank this.
  10. Oxbow
    12,671
    130,692
    Nov 24, 2015
    I'm trying to wrap my mind around this and how the air solenoid operates, because it functions perfectly as is, and the switch in the cab is plumbed accordingly. I guess the air switch itself must have a spring inside which would normally disengage the PTO gear box, and if the mounting is such that it can be mounted the opposite direction and still engage the PTO correctly then perhaps it is possible. It has to be more than just having the air line plumbed correctly (I think).
    Thanks for the help!
    SAR, wore out and snowman_w900 Thank this.
  11. Hulld
    2,882
    6,565
    Oct 19, 2015
    Upstate NY
    Wonder if it's an air solenoid activating a lever?
    If the lever was removed and reattached in the opposite position it would reverse the way the air solenoid activates and deactivates the pto.
    I have seen this before with Manuel ptos when some one puts the lever on upside down and every thing is backwards.
    Oxbow Thanks this.
