Air Suspension Overinflated?
Discussion in 'Kenworth Forum' started by Fyrtrks, Dec 10, 2019.
  1. Fyrtrks
    Fyrtrks Bobtail Member
    Good Morning:
    I have a T270 carrier - roll back I'm trying to learn how to change the amount of air in the rear suspension. It rides very rough like the air bags have as much air in them as they can hold. It also feels like there is no travel left because they seem overinflated.
    Is there adjustment in the leveling valve? I thought the shaft was square allowing only 4 differing positions for mounting that valve?
    I drive another T270 that is 6 years older also with air ride suspension that rides much smoother.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Can you get a pic, there are a lot of different leveling valves out there.
  4. Fyrtrks
    Here it is. Hope the picture works.
  5. AModelCat
    161,679
    People need to start understanding that you CANNOT just dump air from a suspension in the hopes it will make the ride softer. Air suspensions are self-leveling, meaning they will have as much air in them as required to maintain that height. If your ride height is in spec, leave it alone. You'll have a nightmare of a time trying to get your driveshaft angles right.
    starmac, Snailexpress, snowwy and 4 others Thank this.
