air system problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by trucker48, Aug 13, 2013.
  1. trucker48
    trucker48 Bobtail Member
    12
    2006 freghtliner air compressor seem to run constantly air will build to 140 at times before purging and sometimes constant release of air at dryer. Have changed the governor and airdryer along check valve. Any suggestions? Cant hear any leaks and no lines are crossed that I can tell.
  3. Heavyd
    Heavyd Road Train Member
    7,815
    6,267
    Feb 4, 2009
    Put shop air to the signal line from the wet tank to the governor. This will charge the governor and compressor unloaders. If the unloaders are leaking in the compressor you will hear the air leaking back out the main air intake of the air compressor. Bad compressor unloaders could be causing your problems.
    trucker48 Thanks this.
  4. trucker48
    12
    Is that an easy job to replace those? Where exactly here they located ? Like to do it myself and save some money but have not had to replace those before
  5. Heavyd
    7,815
    6,267
    Feb 4, 2009
    Depends on the compressor. Not familiar with what Freightliner is installing now.
