Air tanks slow to build up
Discussion in 'Freightliner Forum' started by Rudy5, Sep 27, 2014.
  1. Rudy5
    Rudy5 Light Load Member
    54
    Mar 17, 2013
    96 freightliner dd 60 series. Air tanks fill up really slow and stay put around 65 psi for what seems to bea long period of time before they start climbing again to normal range of 110psi. I drained ever tank and saw no noticeable loquids. I'm thinking air governor but I'm not certain m any ideas fellas?
  3. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Try the gov. It's only around $15 and you can do it your self. Also, if you can, disconnect the supply line from tak to gov and blow out with air hose.
  4. Rudy5
    54
    Mar 17, 2013
    Ok sounds like a good first step. Thanx
  5. DDFLD
    DDFLD Bobtail Member
    38
    13
    Aug 10, 2014
    Waterford, OH
    I have a 95 FLD, same engine. Mine does the same with new compressor and govener (was making oil). From my experience at around 60PSI is when everything starts to air up (air bags, sleeper bags, HVAC) after all that happens it runs up like normal and never shows any issues after. Just a thought.
  6. Rudy5
    54
    Mar 17, 2013
    Exactly what you said. Everything airs up at around .60psi. Changed the governor out and it stopped fluctuating up and down when running. However, the whole airing out at 60 psi still happens. Oh and yrs my makes a little oil also. Did you ever get it fixed? Thanx
  7. DDFLD
    38
    13
    Aug 10, 2014
    Waterford, OH
    Upgraded the compressor to a now style TruFlo 550. It needed rebuilt. Also, you can check the intake line between the compressor and the engine intake for oil slime. If it is oily its coming from the turbo and not the compressor.
  8. Rudy5
    54
    Mar 17, 2013
    I'm guessing the compressor rebuild is somewhat costly? Guess I'll start saving. Thanx for your comments and advise.
  9. DDFLD
    38
    13
    Aug 10, 2014
    Waterford, OH
    Just get a reman and don't fuss with rebuilding. They will want your old one as a core as well. Good luck.
  10. Bendix Tech Team
    Bendix Tech Team Bobtail Member
    34
    23
    Jul 15, 2014
    to test the compressor get it to 80psi then time it from 80-100psi. should be no more than 40 seconds whether your idling or max rpm. if it is still slow, disconnect the air intake and the govenor, that way the govenor has no bearing on the compressor and the intake wont be restricted and if its still slow to build up pressure then it possbily a weak compressor or maybe something restricted in the air dryer.
  11. Rudy5
    54
    Mar 17, 2013
    Well the test from 80 to 110 was positive. No problems and went right up there. The problem is when I first start the truck and the air tanks are nearly empty. The psi go up slowly but when it reaches 60psi they stall for a long time until finally they begin going up in pressure almost at a normal rate.
