Airbags not equalizing properly
Discussion in 'Trucks [ Eighteen Wheelers ]' started by riles0340, Jul 10, 2022.
  1. riles0340
    riles0340 Bobtail Member
    4
    2020 367 tri drive. The passenger side airbags will not air up to the same pressure as the driver and they'll deflate on their own. Can't figure out why. I've had it into multiple different shops including couple different peterbilts, and they all just replace the compensator. It never fixes the problem. I have override and it will fill and dump.the bags but normal ride height will not hold on its own. Anyone had this issue before?
  3. AModelCat
    161,487
    Single or dual levelling valves?
  4. AModelCat
    161,487
    How's the truck loaded? With a single levelling valve it'll lean to the heavy side. Dual valves should hold it level since left and right operate independent of each other.
    Have seen some goofy things happen in dual valve setups if the valves are mismatched. Some valves react faster and some react slower. They'll fight each other if they aren't matched.
  5. riles0340
    4
    Single leveling valve. When the truck is loaded it doesn't seem to do it, only when it's empty. When there is air in the passenger side there's a very noticeable difference in how much less it has compared to the drivers side.
  6. riles0340
    4
    It's always loaded level. Seems like it's a supply issue to that side
  7. AModelCat
    161,487
    How about the front end? A lean to one side at the steer axle can translate to issues noticed on the rear.
    Has anyone put a gauge on the bags on each side yet to verify if the air pressure is indeed low on the passenger side?
  8. riles0340
    4
    The front is level. No need for a gauge as you can tell from touching it. The right side you can see and feel that it's a deflated bag. If I hit the switch and dump the suspension and raise it again, both side will come up equal. After a short time the right side will deflate, almost like a check valve or something is letting the air past. I can't hear anything leaking one it levels. Is there a check valve somewhere between the leveling valve and the bags?
  9. AModelCat
    161,487
    That's honestly a good question. I always thought all the bags were tied together off of one common outlet on the levelling valve. That may not be the case on this newer stuff.
    Shawn2130 Thanks this.
  10. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    I've got a spread axle trailer that does the same thing between the front and rear axles. I think it has something to do with the dump valve, possibly a check valve integrated into the manual dump switch. When it's loaded it has no problem, but it acts up while empty. If I dump both axles and refill them it will work properly. Hard braking while empty also causes it to act up. Eventually the bags will level out, but it is constantly exhausting air until then.
    If mine were acting up from side to side, I would swap air lines on the bags so that it acts up from front to rear.
