airdryer leaking thru purge valve
Discussion in 'Kenworth Forum' started by T600, Jun 3, 2013.
  1. T600
    T600 Bobtail Member
    14
    Aug 6, 2011
    miami,fl
    I have a wabco airdryer leaking trhu the purge valve and it makes a wistle sound n dont let the preassre build more then 90lbs psi
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I had that problem once on my Pete. Replacing the purge valve solved the problem. I replaced the desiccant canister while I was under there.
  4. boneebone
    boneebone Road Train Member
    2,295
    2,366
    Mar 13, 2009
    Those are easy to change, all you need to do is buy a Rebuild Kit which is about $58.00 dollars. You can change it yourself, all you need is Snap Ring Pliers and 15 minutes, you can change it without taking the Air Dryer off the truck.
  5. stephan
    stephan Bobtail Member
    Theres a small plastic hose take it off if it doesnt leak anymore is the air GOVERNER
