Alert Air Temp Circuit High
Discussion in 'Freightliner Forum' started by Verdel, Dec 6, 2014.
  1. Verdel
    Verdel Medium Load Member
    599
    135
    Oct 26, 2013
    The truck is Freightliner Columbia 2007, DD ser 60 - 14L. I have a ProDriver DC display that is showing this message from time to time. When the message showing up, the yellow check engine light is on and the radiator Fan switches on. After a few minutes everything is back to normal. The water temp. is normal, oil temp. normal. I suspect a bad sensor somewhere.
    Are there any air sensors around the turbo or some other place ?
  3. QUALITYTRUCK
    1,810
    1,773
    Jun 14, 2009
    romulus,mi
    check the black,plastic air inlet temp. sensor on the air filter housing tube.it likes to come unplugged.if o.k.check the wires going to it.check as far as you can.they like to rub on the front of engine by the a/c compressor.sensor is hardly ever the problem.go figure it only costs like $15 and takes 30 seconds to replace.good luck.
    Cheese177, Verdel and train777 Thank this.
  4. bbigcnote
    bbigcnote Light Load Member
    194
    107
    Dec 29, 2008
    northeast, missouri
    my o6 classic has this problem once in awhile too. i unplug and plug back in the ecm water temp sensor and it fixes it. that sensor is on right hand rear of head there are two side by side on is for temp gauge other is for ecm. the ecm sensor on my head is the furthest back
  5. train777
    train777 Bobtail Member
    49
    12
    Sep 9, 2014
    I had the same problem last year, but sold out the truck. Good info.
  6. Verdel
    599
    135
    Oct 26, 2013
    Thank's for the suggestions, I will check ASAP.
  7. Verdel
    599
    135
    Oct 26, 2013
    This problem is caused by bad Air Temp sensor. Replaced Mine and now is all good. The sensor is screwed in the intake manifold, it is made out of plastic. Cost $17.
