Alignment issues
Discussion in 'Experienced Truckers' Advice' started by onekajun, Jan 22, 2011.
  1. onekajun
    onekajun Bobtail Member
    6
    St. Louis, MO
    I am hoping you can help me by answering a couple questions for me. I have a 2007 KW t2000. I have an improper alignment pulling to the right. I took the truck to the local KW dealer in my town for 3 axle alignment and they changed out all the shocks as well. I noticed if I put the steering wheel dead center ...it has a slight pull to the left. If I don't allow dead center steering wheel and do a natural hold or barely hold the wheel it has a slow pull to the right (6-7 seconds for a full lane change). I asked the KW dealer about this and I was told all trucks are manufactured with a slight pull to the right ( personally I believe this to be a load of crap) but as I am out on the road right now there isn't a lot I can do right this moment. I was assured they took it for a test drive as well, but when I got in the truck to leave there was no recorded movement on the Electronic On board pc. Is there any information I need to know or should be asking them. I spent $1,000.... I just want my investment to be well spent and get what I paid for. I don't know what else to do other than bring it back for readjustment when I go home next. Any helpful suggestions?
  3. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    i think they fed you a load of crap.
    who wants to fight a truck pulling in one direction
    also as the tires ware it will start pulling more
    onekajun Thanks this.
  4. pjw044
    pjw044 Heavy Load Member
    With over 20 years as a Alignment Tech what you are feeling is
    called Road Crown Pull. This is the normal slight downward angle of the road slope, for water drainage. A slight movement to the right in the right hand lane is about 5-8 seconds of drift to the right is normal.
    There is road crown on both sides of the roadway, so left hand drift
    in the left lane is also normal. If it requires more than gentle pressure
    on the steering wheel to correct the drift, than you may have either a
    alignment issue or a tire issue. Tire with a slipped or seperated belt can cause a pull also.
  5. o.m.d.
    o.m.d. Heavy Load Member
    827
    2,130
    Aug 15, 2010
    massachusetts
    i was gonna say check your tires, my k5 blazer had a worn out tire, i needed an alignment bad and just one tire was worn uneven, it caused it to pull pretty good, soon as i replaced it no more pulling at all.
  6. ProPilot
    ProPilot Light Load Member
    95
    240
    Dec 26, 2008
    In my truck.....
    I had the same problem with my 2005 T2000 - I also noticed an alignment improvement with a shock change-out. I also have a three-axle done once every 2 months - saving me a buttload on steers.....:biggrin_25519:
  7. wis bang
    wis bang Road Train Member
    3,392
    3,995
    Jan 12, 2011
    Levittown, PA
    I had three Volvo's at one place I managed. The one guy always complained about having to constantly fight the wheel. The Stealership couldn't find any problem. In 125,000 it needed a second new set of steering tires.
    Took it to an independent shop and they replaced the torque arms on the rear, the shocks and did a three axle alignment.
    The driver said it steered better than when it was new. Those steer tires where still on it when the owner sold us out to Bulkmatic...
  8. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    yes --pj hit it right on the mark---the truck is set up to go straight--but the slight crown in the road is what gives it the drift to the right--6-7 seconds for a lane change seems kinda quick---it also depends on the road as well-and the tightness of the steering box
  9. onekajun
    6
    St. Louis, MO
    Just wanted to say thank you for the replies...
  10. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,712
    Jul 1, 2009
    Springfield,MO
    Try an experiment. Next time you are on a 2 or 4 lane non separated highway and you have no one coming at you go to the on coming lane or cross the yellow line or zipper and watch what happens. The truck SHOULD now do a gentle pull to the left! The crown in the road is usually set up so the water drains to the shoulder. 2 lane roads it is crowned in the center the same on 4 lane roads with no median. It's an engineers fix to keep water off the road surface and to drain to the ditches or 'swell" and it might even drain to the side of the road with the better drainage. This means that sometimes you might even get that gentle pull to the left as the right side of the road might be higher than the left so water drains that direction.
    Another reason it usually falls to the right is to get a vehicle to go that direction in case of the driver becoming disabled as in falling asleep or something worse but it doesn't always work that way as we have all seen those head on collisions.
    Oh. if you do try that experiment do it at night so you can see the headlights of oncoming traffic and get the heck back across the center lane but remember this is a dangerous move just to see if it's true about crowing or to see if the truck does "PULL" and not drift.
    The BEST way to see if there is a pull is to watch the wear pattern on your tires. There is a chart of wear patterns you can get from your tire dealer or download but you'd need to blow it up to really see the pictures.
    Another thing to remember about steers is they do take a lot of the forward forces generated by the truck in turns, hitting pot holes and in curbing. Even a "gentle "bump" against a curb can put just enough torque on that wheel and steering assembly to put it out of alignment. Pot holes are hard on your steering and suspension in general. I've watched morons tailgating me and others or just rolling along behind me and I'll swerve to miss a pot ho;le and stupid will drive right through it! After a few times I come to the realization that it's not their truck and could care less and I've even seen O/O's do the same thing!
    Another thing that you as an O/O or L/P should do is get an air powered grease gun or a regular one and once a week put 1 or 2 "clicks" or pumps in your grease fittings on the steering. Do NOT pump until you hear the seal pop and grease comes out as only idiots do that! That's why with MY equipment I did all my grease jobs and let the shop do the oil and rears.
    WHY?
    The seals do two things.
    1) keep the grease INSIDE and on the part that needs the grease
    2) keeps dirt OUT of those same parts!
    When you "pop" the seal you allow dirt into the bearing or knuckle and you also allow grease to drop on the ground, fly up onto your equipment and generally make a DOT officer look at your equipment closer.
    Keeping the front end greases keeps it lubed and "wet" and actually tight and not loose as the grease drys out.
    Get a fold up creeper from Snap-on and a gun, the hose from your truck stop that will hook to the glad hand or put a quick release fitting on a tank and the air line and keep your equipment in better working condition than a "regular" service and save a ton of money rolling around under your $100,000 investment and do the job the proper way!
  11. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    I think I have heard that line just about every time I got my W9 aligned!
