Alignment ....
Discussion in 'Trucks [ Eighteen Wheelers ]' started by acik1983, Jul 16, 2016.
  1. acik1983
    acik1983 Bobtail Member
    22
    Jun 15, 2016
    Good morning everyone!
    Quick question ... We did a front end alignment on one of our trucks aaaaaand the steering wheel is still off (maybe a quarter of a turn).
    What gives and what do we need to do?
    Thanks in advance!
  3. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    If its that much of an inconvenience for the driver..Get a Puller,And set the wheel straight.
    (Some drivers cry because the wheel isn't straight)
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    It's a lot easier to just disconnect the shaft and straighten it out.
  5. AModelCat
    161,852
    Proper way is to adjust the drag link (the link between the pitman arm and the axle). If its non-adjustable, you will probably have to move the steering wheel a spline or 2. Whatever you do, do not remove the pitman arm and put it on a different spline. It will cause you to have too much wheel cut in one direction and not enough in the other.
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yup .
    Just get a cheap steering wheel puller and pop it off and set it straight .
    Your alignment shop should of done that for you.
    Big_D409 and Starboyjim Thank this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,528
    6,587
    Aug 26, 2014
    If you are a 1/4 turn out that could be the shafts between box and the wheel not installed properly. They are not all set up like driveshafts and can cause binding also. Look at a truck like yours and see if yours are aligned the same.
  8. Heavyd
    Heavyd Road Train Member
    7,815
    6,267
    Feb 4, 2009
    Front end alignment should never change a steering wheel that much. If it was straight before I would take it to an alignment shop and have the toe confirmed. Most trucks have one piece drag link, plus, knocking out the draglink end from the steering arm, getting it to turn and reassembly is about 4 times longer and more work than simply popping the wheel off with a steering wheel puller. Also, most steering shafts at the input to the steering gear are master splined, disassembly there to center a steering will most likely end up being a waste of time too. Steering wheel puller is your best bet.
    stayinback Thanks this.
  9. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    swaan is right, the alignment shop should have centered the wheel. One thing, the crown of the road, usually around 10% more or less, will cause a straight axle vehicle to compensate by turning the wheel against the crown direction, maybe 1/4 turn? I'm sure you know that, just looking at stuff.
