All Aluminum Step Deck
Discussion in 'Flatbed Trucking Forum' started by RJ Lopez, Feb 29, 2016.
  1. RJ Lopez
    RJ Lopez Bobtail Member
    35
    28
    Feb 29, 2016
    Need advise ,Wich one should i buy? ,i think for now Benson is out of the question.buying NEW budget is no problem, has to be a 53'on 17.5 ,My Truck is kind of heavy 20.200 lbs with out tarps,chains and binder,or dunage .any feedback will be great.Thanks.
    Dominick253 Thanks this.
  3. Diesel Dave
    8,552
    23,742
    Jan 20, 2010
    Hesperia, Ca.
    I have a heavy tractor also. I would do the combo with the spread.
    Dominick253 and RJ Lopez Thank this.
  4. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Why 17.5? On our trailers that have them, we go through many more tires than the 255 22.5
    RJ Lopez Thanks this.
  5. Ruthless
    Ruthless Road Train Member
    8,816
    86,454
    Aug 28, 2010
    The City.
    17.5's are also harder to find, n when they can be had they are priced like a very hard to find tire.
    They do save a few inches on height.
  6. RJ Lopez
    35
    28
    Feb 29, 2016
    17.5 are becoming more popular this day ,the technological advances we have now have let this little tires to have almost the same load rating.If you drive under 65mph ,as you should with any of this small tires they last a bit longer and thanks to the bad reputation of the past most manufacturer have Tire inflation systems,I see a small advantage over 22.5 on weigth and when we come across loads over 10 feet high
    281ric and Dominick253 Thank this.
  7. cnsper
    5,869
    27,421
    Feb 28, 2014
    The max speed here is 65 so that holds no water, we still go through more tires and the furthest we go with them is the other end of the state. Air inflation has nothing to do with it. 17.5 tires will be spinning faster and as such, they will be running hotter. Hit an elk 80 miles from the nearest large town and 30 from the nearest tire shop. It took out 2 tires on the trailer. Good thing I had a spare because the tire shop only had one. They may be more popular but not all tire shops carry them and not all that do have more than one.
    You can still carry loads over 10' on a stepdeck with 255 22.5 tires. Our step decks average 36-38" high where I read that 33-34 is normal for a step deck with 17.5 tires. Not enough tall loads out there to justify it to me. You probably got stuck someplace once and could not find a load. I could see it maybe if you were going 4 axles but not a spread. For a few loads a year, leave it to the double drops or permit it.
  8. Ruthless
    8,816
    86,454
    Aug 28, 2010
    The City.
    Well being that you've convinced yourself that those tires last and are easy to find, you must have lots of direct freight that needs the extra height.
    Go get you one, ain't gotta convince me of anything.
  9. RJ Lopez
    35
    28
    Feb 29, 2016
    Nope ,don't need the extra space What i need now is to find out who makes these standard all aluminum dropdeck trailers @36 inch height on 22.5 .
    It seems like someone have come across one.
    Besides i posted the thread regarding trailer Quality
    NOT TIRES!
    Thank you
  10. cnsper
    5,869
    27,421
    Feb 28, 2014
    The chaparral that we have stands at 37" with 255 22.5 tires.
    281ric Thanks this.
  11. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    I've been through this. You need a steel frame to maximize your height. Aluminum is weaker therefore they need to use a taller beam to get the the strength. Also keep in mind the longer the span the stronger (taller) the beam needs to be.
    With the above in mind, there are several things that will drive your deck height up:
    1. aluminum frame
    2. large tuck
    3. small spread
    4. long trailer
    5. sliding rear axle
    6. heavy capacity
    My needs were so specific that I couldn't find what I wanted on a lot, so I started contacting dealers about ordering a new one. Most wouldn't even deal with me on one trailer (Mac, Manac, Doonan, Transcraft, Reitnouer) but I did find a Wilson dealer that was willing to do put in the effort so that's why I bought Wilson.
    I bought an 17.5" aluminum framed Wilson that had so much arch in it that the deck height was ~39" loaded at the crown IIRC. So I returned it and bought a steel framed Wilson Road Brute combo with 17.5" wheels and it has a deck height of 35" loaded. I could have got a lower deck height but I wanted a sliding axle and CA legal so that limited me. 53 ft weighs in at ~10,700 lbs. I made sure to order the CTIS, 255 wide tires, heavy duty wheel bearings and a spare tire and rim mounted on board.
    Speaking to a fella that owns a towing company, ,he told me that most 17.5" failures they see are not from tires but burned out wheel bearings.
    I also have two Wilson Road Brute combos with 36" deck and 22.5" (wheel wells).
