All Aluminum Trailers
Discussion in 'Flatbed Trucking Forum' started by SnakeSkinssssss, Apr 9, 2015.
  1. SnakeSkinssssss
    SnakeSkinssssss Bobtail Member
    19
    5
    Mar 20, 2015
    West
    Do they tend to get stress cracks that often around the axles, or is it not that big of a deal. What are the pros and cons.
    If you guys have any answers I would appreciate it.
    Thanks
  3. xsetra
    xsetra Road Train Member
    5,098
    6,952
    Aug 21, 2011
    I own a combo trailer with steel main beams. About 5 years ago my trailer started to crack at the front axle of my spread. The welder that fixed it said all Steel frames will fatigue/stress crack in the same area but aluminum does not. Aluminum has more give when stressed with a shock to its frame.
    SnakeSkinssssss Thanks this.
  4. Ruthless
    Ruthless Road Train Member
    8,832
    86,684
    Aug 28, 2010
    The City.
    I cracked my all aluminum over winter. Up in the neck area tho. I've seen a few alum trailers crack around the axles. Combos I haven't seen many with cracks but I've seen more abuse related damage (operator misuse).
    I've had another all alum no problems at all. And have a combo step currently. No problems aside from rust getting up underneath that's hard to get it all out.
    next trailer I buy will be a combo.
  5. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    We cracked both all aluminum reitnouer beams clean through. Step deck with 121" tandem spread. We think it was caused from dumping the air from the rear axle with a load on.
  6. mtoo
    mtoo Road Train Member
    1,929
    4,433
    Jan 15, 2011
    Retired on bended knee
    My first all aluminum flat was a 1983 Ravens then a 1993 Ravens, a 1995 Ravens, a 2005 Ravens and a 2005 Reitnour. The 83-93-95 all cracked around the front axle. The 2005 Ravens never had a crack anywhere, the 05 Reitnour developed some cracks at the cross members in the neck. The good thing about the Reitnour was they just unbolt and bolt back up.
    If I was to buy a new one, hands down it would be a Mac.
  7. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    I think the welder has inhaled too much toxic fumes.
    Aluminum has about one-third the strength of steel, it also has about one-third the density. Therefore, all things being equal, you need three times the amount of aluminum to equal the strength of steel.
    Aluminum, while being "softer" than steel, is typically less malleable and will endure a brittle crack or break whereas steel can be deformed more and still retain its integrity (the reason the vast majority of metal springs are steel). Think of the difference between steel and aluminum wheels; hit an object on the road and typically the steel wheel will bend while the aluminum one will break.
    So, it may appear to the welder that aluminum trailers have more "give," I suggest it is actually a function of significantly more material (aluminum vs. steel) available to absorb stresses. Impose a big enough stress and it is more likely that the aluminum will break, but the steel will bend. What the welder was commenting on is more a function of design than material.
    BigJls1, rank and SnakeSkinssssss Thank this.
  8. xsetra
    5,098
    6,952
    Aug 21, 2011
    After reading these comments it appears both steel and aluminum crack in time.
  9. BigJls1
    BigJls1 Medium Load Member
    482
    415
    Dec 25, 2012
    Driver THANK you. I read that post and thought great another idiot welder putting crazy wrong carp out there. Steel has way way more yield strength than aluminum. Tensile vrs yield...
    SnakeSkinssssss, not4hire and rank Thank this.
  10. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    aluminum will eventually crack,,hard to find someone that can weld aluminum ,,steel repairs better and a lot more places to get steel repaired than aluminum,, only benefit from aluminum is weight,,if your loads are all 48,000# or more steel is too heavy,,
    steel will have a higher weight rating for concentrated weight is a 10ft or 15ft area..steel tie down spools have a higher rating too,,if all you haul is sheet rock or lumber loads aluminum is about the only way to go because most shippers want you to haul 48,000 to 50,000# loads,,if they they reduce the load weights the rate drops to where it is too cheap to haul,,
    Nene33, not4hire and SnakeSkinssssss Thank this.
  11. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    A huge advantage aluminium has over steel is that exotic forms are fairly easily extruded whereas steel fabrication of complex forms is limited and very expensive even where possible.
    Strength can be derived from ideal shapes and forms with aluminium where this is often not possible with steel. So even though high grade steel and aluminium have similar strength to weight ratios you can usually get better strength from aluminium because it is easier to form in to ideal strength forms.
