All I Transmit Is A Squeal...
Discussion in 'CB Radio Forum' started by Ken, Jul 2, 2010.
  1. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    I have an older Grant XL. It's been in a box for years and years. I installed into my truck and when I transmit all anyone hears is a loud squeal. It recieves just fine.
    I measured the impedance of the antennas and it was 18 M-ohms. No idea what it should be. It has dual 4' fire sticks on it.
    When I did the SWR test according to the manual I was getting 3 on the unit's meter.
    Where should I look next?
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
  4. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    And to think I posted it down here to get a serious answer... :biggrin_25524:
  5. stranger
    3,640
    4,959
    Oct 10, 2006
    NC
    Is it squealing through the cb speaker when you transmit, or can the noise just be heard by other people. It could be your mic.
    Ken Thanks this.
  6. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    Just squeals on other's radios.. I do get a little whine into my stereo speakers though..
    I did just put an RK mic on it. Maybe I'll put the original back on and see what happens..
  7. Scarecrow03
    Scarecrow03 Road Train Member
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    It's most likely your flux capacitor's inability to generate the 1.21 jigawatts necessary to activate the antenna's thermoelectric transducer.
    Just swap your flux capacitor for a Mr. Fusion nuclear reactor and try a different frequency ratio within 6.23924 MHz of top dead center and you should be fine.
    Ken Thanks this.
  8. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    I would say it's probably the SWR is too high. 3 is on the higher end and it
    would be best to have it down around at least 1.
    The lower your SWRs the better.
    Awhile back my SWRs got up there and I was also transmitting just a squeal when
    I would key up.
    Ken Thanks this.
  9. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    I know it's too high.. How do I get it under 2?
    What was your solution?
  10. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    To get the antennas calibrated arent you supposed to trim down the antenna or something like that. I can get a half decent set up going but when it comes to the fine tuning I go to a cb shop.
  11. Scarecrow03
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    In all seriousness, it is entirely possible you threw off your SWRs by swapping antennas. You might have to get a different coax, especially if you're still using the factory stuff.
