All jb hunt company trucks changing over to automatic transmissions
Discussion in 'JB Hunt' started by A Bug, Oct 27, 2018.
  1. A Bug
    A Bug Heavy Load Member
    896
    1,781
    Mar 15, 2014
    Sevierville TN
    At the moment my truck has over 280k miles on it and I put on about 3k a week. So it will not be much longer before I am forced to turn it in and get one of these new automatics, I have never seen a truck with over 400k miles on it.
    My boss says there is nothing he can do, when the time comes automatic are all that will be available. Twice I have driven these things now for a total of about 150 miles all together, and I just do not like the things. Getting the truck to even start has become ten times as complicated.
    I know that a lot of companies are changing over so it is not going to be solved by jumping around to different employers, I am just going to really miss driving a truck that was simple.
  3. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Pray you get one with a creep mode function on it. I have one without it and instead an Eaton and it makes backing a PITA because when you let go of the gas it lets it roll forward and it’s really sensitive with the petal a centimeter is the difference between a slow crawl and dropping the clutch and winging it. One handy thing I’ve learned from an older driver stuck with one is use both your feet. Hold the brake with just enough force to not let it roll and give it enough gas that it overpowers the small brake force.
    Metallica88 and bryan21384 Thank this.
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    The HD account in Pittston PA reportedly has new 10 speed day cabs on order to replace the ones they're driving now.
    Metallica88 Thanks this.
  5. Hillbilly hauler
    Hillbilly hauler Bobtail Member
    29
    34
    Dec 2, 2017
    Well I think I am heading to Pittson as quickly as I can
  6. bryan21384
    bryan21384 Road Train Member
    14,839
    32,094
    Sep 18, 2009
    Memphis, TN
    To me it doesn't make a difference about whether a truck is automatic or standard. Either way, you have to get acclimated to it. Sometimes I don't think it's so much about the transmission. I think some drivers have an image of a what a truck driver is supposed to be, and automatics don't line up with it. Others I think just have a problem with change. An earlier poster made a valid point, use both feet. That helps tremendously when backing
  7. A Bug
    896
    1,781
    Mar 15, 2014
    Sevierville TN
    Being used to what I have now is definitely part of it, more times than I can remember I was still reaching down to shift gears with my right hand or trying or using the clutch pedal with my left foot in the short time that I was driving the automatic.
    But the standard transmission truly is a lot simpler to operate. After twenty minutes of trying to get the thing to drive I found out that it would not go into drive gear with the airbags down. Or that when you turn the key and see the wipers start going it means the power is shut off at the switch. Had to call up roadservice to get help over the phone with that one. Never figured checking the power switch, the wipers were going so assumed power was on and it was just something else that was screwed up.
    Or when you are without a trailer your truck will still drive as if it was pulling a loaded trailer. No starting out in fourth gear and taking off. Almost got into an accident because of that one. I was pulling out into traffic while bobtail and the thing is creeping out at the same speed as if I was 80k pounds and here comes another truck blasting his air horn as he pulls around me.
  8. Ffx95
    1,368
    2,628
    May 18, 2017
    Ahh looks like they gave you a Kenworth or Peterbuilt. I know the freightshakers skip gears. Not sure of the internationals, Volvo, or Macks.
  9. Western flyer
    Western flyer Road Train Member
    2,807
    6,796
    Mar 13, 2014
    What's so hard about just turning the key
    to start the truck.
    You don't have to push a clutch in or
    have your foot on the brake.
    Just turn the key.
  10. Wicked Wizard
    Wicked Wizard Heavy Load Member
    985
    857
    Jul 15, 2008
    Northeast PA
    I heard they are only getting 6 new trucks by the end of the year. The way those guys beat on them, they'll be junk in 3 months. Trust me, was there for 8 years and it went down hill drastically. But that is another thread,
    windsmith Thanks this.
  11. Lightfoot71
    Lightfoot71 Light Load Member
    228
    101
    Oct 28, 2018
    Lower 48
    I drove a brand new Peterbilt a while back and it was surprisingly smooth
