All lights stay on 2000 Freightliner FLD
Discussion in 'Freightliner Forum' started by urgentcare, Mar 5, 2018.
  1. urgentcare
    urgentcare Bobtail Member
    10
    Mar 5, 2018
    All my lights will come on by them self even just sitting in driveway over night. Lights work fine when I use them but sometimes won't shut off by switch. Where to start? 2000 Freightliner FLD Day Cab.
  3. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Do you have a remote that opens your door locks and a alarm? Check the battery in that cursed thing.
  4. urgentcare
    10
    Mar 5, 2018
    I don't have a remote. I guess I could have told you what it is. 2000 Freightliner FLD Day cab.
  5. pmdriver
    2,338
    3,503
    Nov 14, 2017
    Then if you in a area that you run into that mag chloride it has very corrosive problems on wires and electrical units.
  6. AModelCat
    156,872
    First thing that comes to my mind is the relay is sticking closed.
    Second thing is your switch could be sticking closed.
    Third thing that comes to mind is the light circuit has a short to power somewhere.
    BoxCarKidd Thanks this.
  7. urgentcare
    10
    Mar 5, 2018
    Don't think we mag chloride in Memphis that I know of.
  8. urgentcare
    10
    Mar 5, 2018
    I was thinking about replacing relay, headlight & interrupt switches. I have to disconnect my ground wire at batteries at night so if they won't run down.
  9. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    Under 10 bucks for the toggle switch. Start there.
  10. urgentcare
    10
    Mar 5, 2018
    Ordered interrupt switch, they have headlight switch in stock. I have had both switches unplugged and all lights went out. When it was cold outside truck wouldn't crank. Ended up being loose ground at frame from batteries. No problem with lights for about a month. Lights started acting up last week. checked all grounds and they are tight.
  11. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    Of you can access the guts of the switches and they are mechanical with contacts, some Caig DeOxit sprayed in the switches might resolve the issue. Use when depowered and work the switches back and forth to clean the contacts in the DeOxit. $15 for a small can but very little needed, set the nozzle to the slowest setting and the can will last.
    Also, they make battery cutoff switches, even remote ones. Might be handy even if you resolve this issue.
