Alley Docking Question w/ Video....
Discussion in 'Trucking Schools and CDL Training Forum' started by WannaHaulStuff, Sep 1, 2018.
  1. WannaHaulStuff
    WannaHaulStuff Bobtail Member
    25
    Jan 23, 2018
    L.A
    So is this correct from state to state? Im in California
    Can you do a "pull up" like this in the video ( from 1:00 - 1:30 ish )
    Best to start at 0:39 seconds
    I was told ( maybe i misunderstood ) That you couldn't pull up for any of you 2
    free pull ups until you made it in the "Alley Box".
    And if you were to pull up before that you had to start over from the beginning ?
    Hopefully I'm wrong
    thanks
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    When I did my road test I was allowed only one pull ahead.
    CJ701 and Puppage Thank this.
  4. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    depends on the state and thier testing. some allow you to not only do a pull up, but to actually GET OUT and look.
    Puppage Thanks this.
  5. WannaHaulStuff
    25
    Jan 23, 2018
    L.A
    Okay so the state I'm in is California. Anybody know ? thanks
  6. WannaHaulStuff
    25
    Jan 23, 2018
    L.A
    Do you know if its correct to do in California test?
  7. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    you could just go and witness a driving test. or ask your CDL school...they WILL KNOW the answers.
  8. WannaHaulStuff
    25
    Jan 23, 2018
    L.A
    they're closed for the HOLIDay till wednesday (fri to wednesday)
  9. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    and your test is coming up this week..??
  10. WannaHaulStuff
    25
    Jan 23, 2018
    L.A
    The Main thing i was asking though IS Can You pull up the way he did before you enter the "Alley Box"?
  11. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    Pull Ups – When a driver stops and pulls forward to clear an encroachment or to get a better position, it is scored as a “pull up.” Stopping without changing direction does not count as a pull up. You will not be penalized for initial pull ups. However, an excessive number of pull ups will count as errors.
    Outside Vehicle Observations (Looks) – You may be permitted to safely stop and exit the vehicle to check the external position of your vehicle (look). When doing so, you must place the vehicle in Neutral and set the parking brake(s). Then, when exiting the vehicle, you must do so safely by facing the vehicle and maintaining 3 points of contact with the vehicle at all times (when exiting a bus, maintain a firm grasp on the hand rail at all times). If you do not safely secure the vehicle or safely exit the vehicle, it may result in an automatic failure of the basic control skills test.
    The maximum number of times that you may look to check the position of your vehicle is 2, except for the straight line backing exercise, which allows only 1 look. Each time you open the door, move from a seated position where in physical control of the vehicle or on a bus walk to the back of a bus to get a better view, it is scored as a “look.”
    Section 12: Basic Control Skills Test
