Alum.Dump how big of rock
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by istumped, Jan 16, 2020.
  1. istumped
    istumped Medium Load Member
    497
    234
    Feb 8, 2015
    How big of rock would you haul in a aluminum frame trailer with liner(liner does go up the sides alittle bit). May have a job coming up that requires 1x3 rock. My only concern is damage from rock when loading. Thanks
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Rock three inches long and at least one thick?
    You will need to have a front end dozer who knows how to be gentle. Lay down the first layer in the bottom with two scoops and then go ahead and dump the rest in. We had stone trucks with steel buckets of about 30 foot trailer with mack R's and did not care less what went in there.
    My old Dump was also a alumum bed, we hauled rock about that size constantly with no apparent damage but I am pretty sure if you really looked it over there are dents.
    Aluminum is not my choice versus rocks. Especially if they are really big rocks.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I would not be afraid of 1X3 rock, especially with a liner.
  5. GFTLLC
    GFTLLC Light Load Member
    75
    80
    Jan 4, 2020
    Pennsylvania
    I haul stone about that size almost daily in a steel frame aluminum dump. Trailer has some age but i dont see it causing anymore wear than I would consider normal. Been running the same haul for years in a triaxle before I got my own. The trailer I use has no liner. Only this is to make sure whatever area you are loading the stone isn't frozen into clumps. If so make sure the loader operator has sense enough to break it up. If not I'd ask them too because that will cause denting issues. Hope this helps and good luck.
  6. TRS Group
    TRS Group Light Load Member
    93
    117
    Sep 24, 2018
    1x3 rock won't do much damage to an aluminum bed even without a liner. You shouldn't worry about anything with that load ...well except tarping. Tarping 1x3 with a pull tarp sucks
