Aluminum in oil sample
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stuart wood, Jan 24, 2016.
  1. Stuart wood
    Stuart wood Bobtail Member
    5
    Just had a oil sample come back with high aluminum only. 60 ppm. Had egr cooler replaced 2 oil changes ago but had no aluminum in samples done for those oil changes approx. 20000 miles per oil change . All other wear levels are good to excellent. This is on a 2009 Volvo with d13 and dpf filter. Anybody got any ideas. Thanx big vette
  3. xsetra
    xsetra Road Train Member
    5,104
    6,967
    Aug 21, 2011
    Aluminum could show piston or bearing wear (internet search). Send another sample and compare.
  4. Stuart wood
    5
    Thanks . Just did that ,waiting on results
  5. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Sounds like it could be piston skirt.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    What engine? some Cats this indicated a fuel pump.
  7. Yes. How many miles? More info...
    My bad. Glazed over it as I red.
  8. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Not to many aluminum parts in engine.
    Bearings overhead and crank shaft
  9. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    read the first post it says what motor it is
  10. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    As they said in the military, RTFQ.
    Your right it is there. 2009 Volvo D13
  11. Heavyd
    Heavyd Road Train Member
    7,761
    6,201
    Feb 4, 2009
    Coolant will have aluminum in it which can transfer aluminum to the oil from the EGR cooler failure. Always go with two oil samples in a row to confirm.
    Snailexpress and BoxCarKidd Thank this.
