Am I reading this CA regs right?
Discussion in 'Flatbed Trucking Forum' started by ChipW, Jul 18, 2014.
  1. ChipW
    ChipW Light Load Member
    135
    99
    Nov 12, 2007
    Chester, SC
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    YEP! 48' trailer, you're good to go play most anywhere in the state. There are some coastal/mountain highways that will have overall length and off-track restrictions, so just be aware if you venture off the main routes!
    ChipW Thanks this.
  4. jsprocket
    jsprocket Heavy Load Member
    830
    262
    Nov 4, 2013
    Columbus, GA
    I had an inspection while in California with a 53 and no one said a word
  5. Knucklehead619
    Knucklehead619 Medium Load Member
    537
    591
    Mar 11, 2014
    Flyover Country
    It's generally (but not always) pretty well posted where there are trailer/kingpin setting restrictions. 48' spread axle will be legal in the majority of places in CA but if you plan on getting off the beaten path do your research to make sure you're good. CHP absolutely loves screwing with truckers and they'll nail you if you give them a chance.
  6. REO6205
    REO6205 Road Train Member
    13,172
    60,499
    Feb 15, 2014
    California.
    born&raisedintheusa Thanks this.
  7. ChipW
    135
    99
    Nov 12, 2007
    Chester, SC
    I'm going to be just riding through on my way up to WA. But I did turn down a run into CA because I was told 48' fixed axle trailers weren't allowed anymore since the KPRA is longer than 40'.
  8. Boardhauler
    Boardhauler Road Train Member
    1,715
    3,501
    Dec 21, 2008
    Ballin' in it for Shakey
    The 40' KP to RA is only for trailers LONGER than 48'. With a 48' you're good to go as long as you stay off certain state highways and away from municipaities that have a 65' OA length limit. Unless you have a short enough truck to get down to 65' OA with a 48' trailer. I do it with 216" WB on my Cascadia, with a 379 or W9 you need to be about 235" or shorter. If you're just going through on the interstate, you'll be fine.
  9. Diesel Dave
    8,716
    24,948
    Jan 20, 2010
    Hesperia, Ca.
    Boardhauler is correct. I run Cali and pull from 40's to 53's but mostly 48's and my truck is 265 wheelbase. Long as you run interstate highway you will be fine. State routes are different in the other hand. I was on a state route 2 santa monica blvd one block away from 101. I got pulled over, was measured 71 feet overall. The company I hauled for split the fine, $191.00. Also, the LEO wouldnt except my annual oversize permit. Says I was in los angeles county jurisdiction, not on a interstate. I think I could of fought it But would of lost more money losing work for the day.
