Ok, I am in a 2014 ProStar+. Company Truck. Stock middle-of-the-road radio, IE; AM-FM/CD/MP3/USB
Here's the problem. The AM reception in this truck is virtually non-existent. I need the AM band to listen to Rush! It seems I can only pick up when i'm right on top of a station. I'm talking 20 miles MAX on solid powerhouse stations. Channel searching is useless unless I'm "in town".
FM reception is not much better, but is useless to me, because that's what I have satellite radio for. The music I want to listen to is, for the most part, only on satellite. plus I don't have to search while I'm driving. Tune to my music and let the miles roll.
Now, oddly enough, I have found out that if the truck is off or if I step on the brakes ( that was a REALLY mind boggling discovery) AM reception greatly improves. However, BOTH of those situations mean no wheels turning. No wheels turning = No $$$ So the likleyhood of sitting 3 hrs a day, just to listen to a radio program is not happening!!!
Soooo, Any Ideas how to improve reception???
Also, any idea if I need a "special tool" to remove this radio ? I don't see any screws around the faceplate. Just holes that look like I need to stick something in to unlatch (?) something.
Any advice is greatly appreciated as this is very frustrating. I'm going thru Rush withdrawals . My other trucks had decent reception and this wasn't an issue as much. But this one I will be in for a while as it was brand new when they gave it to me. Even if I have to get a new radio, How do I get this one out if there's no screws???
HELP!!!
AM Radio Reception (Help)
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by All-American82, Sep 19, 2013.
I have good AM using the same radio I used in the previous truck, it works better in this one. The radio that came in the truck didn't work well for AM and didn't have weather band so I had my own put in.
Reception issues, many of the Prostars have a dedicated radio antenna on the cowl, passenger side, where it curves around,it looks to have been added later.
There is an L shaped tool used to unlatch the locking collar and the radio can then be pulled out. The shop guy managed to get the radio out of mine without the tool.mje and All-American82 Thank this. -
The Radio is either not wired correctly or their is an internal fault within the radio . Personally I'd go with the internal fault within the radio..
But can't you pick up Rush on Satellite?mje and All-American82 Thank this. -
If only the interwebz had some sort of "engine" that could facilitate us in searching for information. Maybe someday that will happen. In the meantime....
http://www.ehow.com/how_5101520_improve-car-radio-reception.htmlAll-American82 and mje Thank this. -
If reception improves when the brakes are on ( I assume the brakes are set when engine is off) you have a bad ground on the cab (antennae) making the reception poor while brakes are released. You can double check this by firmly engaging the clutch brake and reception should get a little better. A ground wire to the antennae is the simplest fix, or maybe I-Heart radio app on your smart phone, should plug into your MP3 player port. You are supposed to have 2 V or U shaped specialty tools to get the radio out but 4 long narrow allen wrenches or 4 long narrow torx drivers will get it out if you are careful.
All-American82, mpd240 and mje Thank this. -
I'm inclined to think you may have a connection issue with the antenna caox going to the radio. Maybe a bad coax or it's disconnected in the back of the radio.
nope Rush is not on any satellite network. Wish he was. I'm sure he has some sort of contract(s) forbidding him from broadcasting over [even Rebroadcasting] satellite for the foreseeable future. Guess you could subscribe and do his podcast technology. When I can get rush it's always a conflict deciding between him and Wilkow (on satellite) in that same time-slot. Sometimes, one is more interesting then the other and it flip-flops.mje and All-American82 Thank this. -
Where did you find your avatar, I was Alpha co 1/325 1990 to 94. Not that I would use it on TTR but would be really cool to have.
Thanks to All !!!
No Rush is not on satellite unfortunately. And yes to the Wilcow majority! I do switch back and forth depending on topic.
The brake issue is, when I STEP ON the service brakes is when reception improves (go figure). In other words, when I'm coming TO a stop.
Now that I have an Idea how to get the radio out I should be able to pull it out and check the ground. And if that doesn't work Ill just have to replace it.
Doesn't the Iheart radio use your Data? I have Verizon with data and went over once and used it on a run in Alberta and WOW $$$$
And Lastly, but definately not least. Google search your unit in "images" and you'll be suprised what you come up with.
FYI, HHC3RDBDE. '77-'80 At the time we had the 1- 2nd/505 and 1/508
All the way!!! -
In some trucks the AM/FM/CB antennas are the same.
That probably doesn't help.
Not really sure I never listened to AM..and don't remember last time I listened to FM.mje Thanks this.
