Ambassador bridge- Detroit- Transponder
Discussion in 'Ask An Owner Operator' started by haider99, Jul 14, 2017.
  1. haider99
    haider99 Medium Load Member
    685
    108
    I have crossed this bridge from Windsor,Ontario and both times CBP officers said the license plate on the transponder does not match my truck's and they made me go inside and pay $13.05
    They also said that their ACE has the incorrecr license plate number and I am putting it in which I am not. I believe this plate number is of the previous owner.
    Did anyone here experienced this and how can I resolve it. The officer was pretty .ad this time.
    Also, thats the only fee I have paid while crossing...Is there anything else that I have been missing?
    Thank yoi
  3. Ridgeline
    22,642
    120,741
    Is the transponder from your account?
  4. Lostkeys
    Lostkeys Heavy Load Member
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    I had a similar problem when I bought a truck. My carrier gave me a temp plate to use until the permanent one showed up. And when I switched plates, I had problems with customs. Customs explained to me that people and vehicles have separate files and that my tractor file would have to be deleted and a new one created. Our ACE provider had to 'go into the system and delete my tractor file' and create a new one. I had to lean on my ACE provider bc she blamed customs and customs blamed her. Once she replaced the file I never had another problem.
    Customs has their own transponder and the ambassador bridge has their own transponder. The ambassador bridge is only electronic tolling anymore. Fyi, go slow over the scale or you can be tolled full weight even when you are empty. Also the toll rates are different crossing into and out of Canada.
  5. haider99
    685
    108
    Nope. Previous owner
  6. haider99
    685
    108
    Since I make the manifests...i dont know how to delete said file
  7. Lostkeys
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    rank Thanks this.
  8. Old Iron
    Old Iron Road Train Member
    1,158
    20,284
    Feb 19, 2011
    NW Wisconsin
    Can't help with a transponder. I've never had one.
    But If the transponder isn't yours then I'd get rid of the thing.
    I use a permit guy for my E-manifest.
    @rank is the one to ask, I believe he does his own.
    rank and Bean Jr. Thank this.
  9. rank
    rank Road Train Member
    9,919
    113,508
    Feb 11, 2010
    On the US customs Transponder issue, it sounds like the transponder is tagged to the previous owners plates. Not sure you can transfer the transponder but you can try. Google "DTOPS transponder" and the phone number should be on the website.
    For the ACE issue, yes it sounds like the previous owner had that VIN in the ACE database and the people that are doing your ACE are using the old info (old plates). You can try contacting the previous owner and maybe they will delete it. We had the same issue with one of our trucks. There is a way around it but I have to remember how I did it. Maybe by doing a one time entry for the truck.
  10. haider99
    685
    108
    I contacted someone and they told me to make a profile on DTOPS and tranfer the transponder. I will do that once I get home because I am stuck with another issue.
    So near our delivery in IL. Trailer leveling valve bolt broke which pumped up the bags causing the tip end of the trailer to hit a bridge. This caused most of the frame to come off. Now, we are at a shop getting it fixed. One side is in but the other side isnt going in because top frame is bent. There are straps holding the other end in place.
    Now, I would like to take a load back to cover some of the costs. Should I?
  11. rank
    9,919
    113,508
    Feb 11, 2010
    I can't help with that. I'm a flat bedder and a grain hauler. But here is the DTOPS URL and the phone number.
    CBP DTOPS
    (317) 298-1245
    Mon.-Fri. 8am-4pm Eastern
