Amp install ????
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by logans, Nov 8, 2017.
  1. logans
    logans Light Load Member
    81
    17
    Sep 19, 2010
    Cookeville tn
    How to install an audio amplifier in a cascadia without company seeing it and the wirring? Worried more about the power hookup to the battery.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,383
    8,587
    Oct 5, 2012
    Earth
    You don't own the truck. Don't modify it. This is a bad idea.
    tscottme and Roberts450 Thank this.
  4. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Sounds like a perfect way to be looking for a new job. Does the company have an agreement with you? That keeps you from adding this item or items?
    I know if it were my truck. And a driver wired up stuff without approval. That driver would be fired. These newer trucks, lots can be screwed up. Just wiring up something. And today's stereo's do a great job. If it does not have enough power. You may need new hearing aids.
    Tb0n3 Thanks this.
  5. Brandt
    Brandt Road Train Member
    4,466
    6,089
    Sep 17, 2012
    These new trucks send multiple info for the computers to run the truck on the same wire. It's call Multiplex wiring and it takes 5 or 6 computers to run the truck down the road. I wouldn't cut into the wires unless the company ok with it.
  6. BlackThought
    BlackThought Medium Load Member
    562
    462
    Jul 22, 2014
    Memphis,TN
    Get a power drive 300 w invter and use your 12v outlet that has the best fuse and make due with home speakers.
    Had enough bass to turn heads at stores.
