Amp not working?
Discussion in 'CB Radio Forum' started by Pool6710, Nov 8, 2015.
  1. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    I'm using a stock bc880 CB, should be about 4wtts.
    Trying to run a MS500 and it doesn't appear to be helping at receiving or reching out.
    Running a Wilson 5000 and my SWR is very close to 1
    Without a meter to check the watt output is there any way else to check to see if it's working?
    I might also not be supplying the amp with a quality power source. I have it connected to the + and - on the side of my dash for the CB.
  3. kor b
    kor b Light Load Member
    254
    103
    Dec 16, 2008
    Your right about not feeding it enough power. A 500 watt amp should have at least 6 gauge fine stranded wire direct to the battery. I would use an external swr/watt meter to test it. 1.3 to 1 or better is ideal although 1.5 to 1 or better can work ok. The way I test for performance is I get on channel 19 around a lot of truck traffic and praise Obama, Obama Care, or Democratic polices in general, then set back and listen. Lol
    burnsey, Blaskowitz and Pool6710 Thank this.
  4. Pool6710
    662
    258
    Aug 10, 2014
    Minnesnowta
    Alright I'll wire it up tomorrow the correct way.
  5. rabbiporkchop
    9,681
    6,538
    Feb 9, 2012
    Wapwallopen, Pa
    I'd hook it up on a bench tuned for 11 meters and see what it looks like on a scope.
  6. Pool6710
    662
    258
    Aug 10, 2014
    Minnesnowta
    Just tried it with the correct wires and the amp made my watts lower. The fan turns on and the lights work, but I think something is fried in it?
  7. burnsey
    burnsey Light Load Member
    81
    40
    Jan 24, 2014
    seacoast, NH
    Why did I not think of THAT before ??? :laughing-guffaw:
  8. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Are you sure you have the coax connected the right way at the amp?
  9. Pool6710
    662
    258
    Aug 10, 2014
    Minnesnowta
    correct, I could hear people too, couldn't reach them though.
    Even turned on the pre amp and they almost didn't register because it lost watts with the amp on.
  10. RockinChair
    RockinChair Road Train Member
    5,276
    13,753
    Feb 19, 2012
    Lubbock, TX & thereabouts
    How do you know you're getting less wattage? In your first post, you said you don't have a wattmeter.
    rabbiporkchop Thanks this.
  11. RockinChair
    5,276
    13,753
    Feb 19, 2012
    Dam.mit boy, that ain't right...
    :thumbup:
