Annual truck and trailer inspections
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by FL120, Sep 1, 2022.
  1. FL120
    FL120 Bobtail Member
    Sep 1, 2022
    Has any owner operators out there having problems with some brokers not wanting to use them because the FMCSA is not showing an inspection in the last 24 months?
    Chieftains Thanks this.
  3. Rideandrepair
    17,325
    56,210
    Aug 8, 2015
    Yes, twice recently. Makes no sense to me.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    Just to make it clear.
    An annual inspection as required by FMCSA is not the same thing as a CVSA inspection.
    Now if the brokers are talking about an FMCSA annual inspection, simply get it done at any shop.
    If they are talking about a CVSA inspection (CSA) then nothing you can really do. You can ask for an inspection, but by default the answer is no (as per CVSA guidelines).
  5. Rideandrepair
    17,325
    56,210
    Aug 8, 2015
    Good point. We’re referring to Snapshot.
    ZVar and Big Road Skateboard Thank this.
  6. Big Road Skateboard
    6,153
    33,644
    May 2, 2021
    It's not annual inspections, it's actual inspections by DOT.
  7. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,424
    Jan 27, 2013
    Austin, MN
    Makes perfect sense. Look in the for sale section here at all the illegal double-brokers chomping at the bit to buy MC numbers with inspections on them. By requiring an inspection, the customer knows the company booking the load actually has trucks and aren't illegally double-brokering the load to skim more money off and then often failing to pay or paying the driver late.
    This is also why some customers will require your MC number at pickup... it has to match the number of the "provider" who booked the load. If not, you can't get loaded because they know you were the victim of a double-broker scam.
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,325
    56,210
    Aug 8, 2015
    So that’s the reason. Makes sense.
